Bias ply rear / Radial front = REAR SWAY ??
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Forever I've read running a bias ply rear with a wide-ish radial fronts you get crazy sway going WOT in a straight line with these IRS cars. I dunno about that man. Running 28x11.5.17 ET Street R rears & Firehawk Indy 500 245/40R19 fronts there is zero sway. Street / track / 4x4 trails (haha). It's just hook like a mofo & hang on. In fact, I didn't notice anything unusual other than the bias plys grab the ruts in the street more. So makes me wonder what these guys are doing to get all that sway. Don't wanna get caught off guard haha. Cheers.
cahouston
Houston
2019 Mustang GT A10 Premium
What do you have the rear air pressure at? That makes a difference typically.
WildHorse
WildHorse
N/A or GO HOME
'17 S550
cahouston
Houston
18 psi rear / 32 psi front
That is good you aren't experiencing the sway effect. My 2006 GT had no sway bars and with a radial front tire and MT ET Street bias ply in the back, it definitely had movement at the top of the track. At highway speeds, it felt pretty floaty as well. Street driving below 50mph felt fine. I have run the same 17x9 wheels with the bias ply tires on my '19 GT with stock front wheels and it felt fine under 60mph at 18psi but around 65-70 on the highway, it does not. I definitely felt that movement and like you said they tend to catch and ride the ruts or imperfections in the road surface. I wouldn't consider it dangerous if you know to expect it but it can be unsettling at times.
Anytime I have street driven a bias ply rear tire, I have taken turns very easily as well. Straight line though, it's a blast!
WildHorse
WildHorse
N/A or GO HOME
'17 S550
Turns ain't to bad. Had to do an pretty violent emergency maneuver to avoid some jackass the cut me off then slammed the brakes cause 'he needed that lane'. Handled it like a champ haha. Somebody told me to pump up the front psi at the track from 32 psi to 42 psi. Regardless though.. I need to get some pizza cutters for up front.
Braski
Lancaster, PA
Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
With the Hoosiers I had alot of sway even with bias up front. I changed to MT Street bias r's and had zero sway. I was even running them down to 12-14 lbs cold and they felt good. You will pick up a tenth or so and atleast 1+ mph if you go with a skinny upfront.
WildHorse
WildHorse
N/A or GO HOME
'17 S550
qtrmiler2
streator,il
greg
2018 mustang gt pp1
Had mt 19 drag radials on my 18 pp1.The sway was bad at any tire pressure.Call mt the daid that had issues with sway on the mustangs due to the way the tire was built.Reconmended going to 17 in rim and tire.
WildHorse
WildHorse
N/A or GO HOME
'17 S550
Well I pumped up the fronts to 40 psi, rears at 19 psi. Got an alignment with the MT on and all is good now. No float/sway/etc.
CoyoteTX
Central Texas
Randy
2015 Ford Mustang GT Premium
[/QUOTE]
Love the setup! How wide are your rear wheels? And are you auto or manual?
Rapid Red
Woodstock GA
Greg
Bias & radial not a great idea, get in the wet the rear will come around on ya.
Put a corvette into a wall once with that combo. Been a while, may be things have advanced .
WildHorse
WildHorse
N/A or GO HOME
'17 S550
Thanks ! 17"x9.5". Manual
Good thing I don't drive it in the rain. Otherwise it went straight as an arrow. Got my best 60' ever.
CoyoteTX
Central Texas
Randy
Are those Forgestars on the front? What’s the specs on those as well? Sorry I’m just getting into taking my mustang to the track and I’ve never done this before lol
WildHorse
WildHorse
N/A or GO HOME
'17 S550
Nah.. just some stupid AM 19"x8.5" w/ firehawk 245/40R19 tires. No need to say sorry. If I can help, I will. Cheers.
