Best Brembo spreader ?
ANGST
Herndon VA
18 Cayman GTS, 15 Explorer Sport , 09 Honda Fit
What works best to spread the calipers ?
Or just use a c-clamp ? I’ve never changed brembo pads before.
gtorpedo
Arlington, Virginia
2015 Mustang GT Premium PP
If you can find a “good” deal on one, the Girodisc pad spreader is the way to go on the 6 piston Brembos. I picked up a slightly used tool for ~$125 i beleive - very pricey but very effective.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
whalesalad
Costa Mesa, CA
2016 GT PP
I used my thumbs. Seemed to work pretty well. Or a screw driver if you carefully apply pressure on the ring portion of the piston, going from side to side so you don't bind it up.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I usually just use a pair of C clamps.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
I got this, and based on the width, it should be enough to get all 6 done. Works like a charm for the base GT 4 pistons which is a larger overall caliper and similar pad size.
Are you running two bleed hoses and cracking both fittings?
Norm
BmacIL
Enginerd
Naperville, IL
Norm
I bled afterwards with the new pads on, MC reservoir cap was off when using this.
Grimace427
NoVA
2011 Mustang 5.0
I use channel locks and large flat screwdrivers. If the calipers have a nice painted finish I'll put a rag or fold up some paper beneath the channel locks to protect the finish but otherwise no special tools necessary. Especially if you are only replacing the pads you can just remove one at a time, no need to press out both sides at the same time.
ctandc72
VA
'19 GT 6 speed Base
Old brake pad and C clamp. Never had an issue on any type of push in caliper piston using this method.
Norm Peterson
Norm
'08 GT #85, '19 WRX
I always bleed afterward as well.
I just can't make myself push the dirtiest fluid in the system back toward the ABS HCU for any reason.
Norm
BmacIL
Enginerd
Naperville, IL
Norm
Probably a good idea, though I was doing a full flush anyway.
