Base Model Ecoboost 3.73 Gears
KadenW23
Dallas, TX
Kaden
2015 Mustang Oxford White Ecoboost
Has anyone had any experience with putting new rear gears in our cars? I have the base model 3:15, and I want to jump up to 3:73. If so, where did you buy your gears from?
speedfrk
Atlanta
www.nationalsuperbike.com
Curt
2023 F150
Don't think 3.73 will fit in the 3.15 housing. You will need to swap the entire diff.
Fast64ranchero
Meridian, Idaho
Walt
63 Ranchero, 1972 Pinto, 2015 Mustang
There's a couple of us that have 3.73's. Your 3.15 housing will not work. Best option is look for a complete carrier out if a GT PP
ElAviator72
Canby, OR
Brent
2016 Ecoboost PP Deep Impact Blue (base 100A car)
Also, be aware that Ford uses cast steel housings for the manual transmissions, and aluminum for the automatic...but I'm wondering if an aluminum 3.73 housing will work ok in a MT car? Since it is engineered for the V8, I'm thinking you could probably get away with aluminum on the manual in the ecoboost... ;)
Oh, and obviously a diff swap where you're changing ratios is going to require a PCM re-flash to tell the PCM about the new rear end ratio!
KadenW23
KadenW23
Dallas, TX
Kaden
Of course! well thank you guys for all your info, I think I've got everything I need,
