Bad wheel bearings?
Belalk
Flint MI
Belal
2018 Mustang GT PP1
2018 GT started making a very obnoxious drone noise when driving. Tires are brand new and I switched out the wheels and am still getting the noise so I know it’s not that. I believe it’s wheel bearings but just wanted to get a few more opinions. Let me know what y’all think.
Gets louder at higher speeds, I can feel the vibrations from the noise.
Turbeau
Calgary, Alberta, Canada
2022 M1 HP 6SPD JFG
Jack the wheels off the ground and give them a wiggle side to side. There should be zero play. Otherwise bearing are shot - I have also seen carrier bearings and u-joints make a similar noise. While you're under there check all rotating items (drive shaft, half shafts)
Belalk
Flint MI
Belal
2018 Mustang GT PP1
Yeah that’s what I did, seems like it’s the front driver side bearing. Could also feel the spring vibrating when I spun the wheel, other side didn’t make the same vibration.
Thanks!!
Adam the Lighting Guy
West Palm Beach, FL
Adam
2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
I'm in the same boat. Hums while going straight and in right turns. Becomes silent in left turns. Already swapped out the fronts. I didn't have any play left right up down on any of the wheels. I assume it's gotta be the rear bearings at this point.
