Bad shifter vibration
BIGGRAY
Chicagoland
Ray
2017 Chevy SS
Hey all,
I have a 2019 GT PP1 MT82. I have a MGW X-Spec Shifter installed. Recently I am getting horrible vibration at 3-4k RPM. It happens both while driving and sitting still. If I sit in the drive way and hold my RPM'S at 3k, my shift knob rattles like crazy.
My shift dampener (batwing looking weight) did fall off on its own about 1-1.5 months ago, but since many people seem to remove it anyways I figured it wouldn't cause my issue. Since it also vibrates in neutral sitting still, would it be a motor mount? Trans mount?
I made sure the MGW bolts are all still tight, I re-did the lockout bolt on the MGW, and I made sure the bolts for the trans support were still torqued (they were)
I'm at a loss. Please help!
stannypack
NOVA
2022 Mustang GT
oof hoping my install next week goes smooth
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
When did the issue start? Has it been there the entire time you've had the MGW shifter or did it start right when your shift dampener fell off (I don't have the MT82-D4, so I don't even have a shift dampener anyway)?
The MGW is transmission mounted so you're going to get more vibrations through the shift knob, period but it shouldn't be anything crazy, just a light vibration (i only notice at idle with my MGW).
The problem could be from something not connected as securely from the shift linkage to the transmission or if you installed a stiffer transmission mount as well, you'd get more vibrations there too.
BIGGRAY
Chicagoland
Ray
2017 Chevy SS
It started this summer... Maybe 1.5 months ago? I started noticing the vibration once the shift dampening weight fell off the transmission. The MGW has been installed for 3 years. Never had vibration like this before. I double checked the MGW nuts and bolts and everything is still tight. I have stock transmission and motor mounts too...
Howitzer
NC
flickr.com
Howie
I'm not familiar with that dampener but it seems like it may actually have a purpose on the MT82-D4 if that's when you started noticing this. How did it just fall off? Are you able to re-attach it?
BIGGRAY
Chicagoland
Ray
2017 Chevy SS
Many people remove it. Built D4's actually just install a cover plate. Odd that they won't have my issue when removed. But I hear you it makes sense the weight stopped the vibration...
Howitzer
NC
flickr.com
Howie
Yeah, I'd start with just re-attaching that dampener to see if there's any improvement. If not, you can look further.
That_white_gt
Vista CA
Logan
1988 Mustang gt convertible(aod) 2018 mustang gt pp1 M6
I know this is kinda old, but its the stock dual mass flyhweel. Its a piece of trash.
