higdominator
- Aug 6, 2015
- Central Oklahoma
- 2016 GT PPP
I'm currently looking for a plug and play system so that I can run straight E85. In this search I suppose I could post up what I know and gather information from others as to what is available for the EBM.
So far there are only components that I am aware of:
*CP-E: Fuel rail system http://cp-e.com/webstore/product/ecoboost-2-3l-turbo-fuelbar-fuel-rail/
Allows 4 injectors to be added, essentially is a factory styled port injection adapter.
Requires: 4 Injectors, controller.
$713.44* PM [email protected] for serious pricing inquiries.
More info about CP-E's kit:
http://www.mustang6g.com/forums/showthread.php?t=27775&highlight=fuel+rail
http://www.mustang6g.com/forums/showthread.php?t=35106&highlight=fuel+rail
*FFTEC: Pending Release
*Lethal Performance: Plug & Play kit using CP-E rail. Pending Release
* MAPerformance - Tested to 650RWHP, not yet in production. TB spacer with 2 injectors. Pending release.
* Stratified Auto
Has a throttle body mounted solution like their 2.0 EB kit. Recent conversation did not reveal a release date, but it is in the "works".
This system comes complete with all components including two 700cc injectors and Split Second control module.
2.0 EB pricing was $900.00
**** NOTES ****
For TB injection it has been recommended to use slightly larger injectors: GT500 injectors are perfect.
For the CP-E kit injectors from K20A2 Honda's or 30# Ford Injectors are preferred.
** Adam has stated that the MAP car had plenty of fuel using a single 60# injector. Please speak with your tuner first**
If you use Split Second: Choose the device corresponding to you injector count and using GUAGE pressure. You will also need a Tach Adapter such as those made by MSD, Autometer, and others.
I recommend Tune+ Aux Fuel tuning but to each their own.
* Stratified Auto
**** NOTES ****
