Bluemustang
You might notice a good difference with FR toe bearings. I do not have the diff bushings or the LCA bearings as you know. I tried several takeoffs like you described - the car just drifts and then hooks up and corrects. No tire shake or wheel hop. Much better than stock. I think there is a good reason Ford put it in their track kit.Not yet but I think I'm going to do those before the LCAs. It's important to me to install one mod at a time so I can evaluate the good/bad and decide if the mod stays or not.
So, my next mods will be in this order:
1. Diff bushing inserts, then
2. FR toe bearings, then
3. LCA bearings
Oh yes, totally, not to mention the LCA bouncing fore/aft as the wheel fights for traction. I've also got high hopes for the diff bushings.
Note taken on the poly links although my car will never see a drag launch if that's worth anything. That said, once the diff/toe/lca parts are in I will remove the links to see if anything is lost, since, they seem to provide only a marginal benefit at this point.
The poor traction in the rain has always been there in my car but no wheel hop cornering.
Still, I am willing to bet I could improve it significantly with 1. Better tires and 2. LCA bearings and then 3. The diff bushings. I will be doing this most likely in the spring once I've saved up enough cash.
