Are TPMS needed?
Schu
Las Vegas, NV
S550GTPP
I'd like a clear resolution on this before running aftermarket rims... I dont really need tmps, but this issue has been a hindrance before.
Mikeg4572
Mikeg4572
Scottsdale, Arizona
2015 Magnetic GTPP
I'll be the guinea pig
DickR
Raleigh
Or just buy the sensors. ;)
Easy for me to say since I drive long distances on my autocross tires and actually want the sensors to avoid the light but even more importantly to give me early warning of a tire problem so I might be able to avoid destroying a set of autocross tires.
Renner
Huntley, IL
2016 GT SOLD-2015 Ecoboost SOLD
So unlike other cars is there is no way to turn off TPMS 100% even with using a OB2 cable? Also I am used to a VAGCOM cable that Audi/VW uses to adjust certain features...does Ford not have this?
Grintch
Hunstville
2015 GT PP
Assuming the track wheels don't get significant street use there are two potential advantages to the new TPMS:
1) IF a tire starts to go down significantly or the car starts to feel strange you either get a warning or you can preemptively check.
2) You can monitor the approximate tire pressure change as the tires heat during a session.
CJ Pony Parts had them in stock at relatively low cost compared to previous Ford sensors. http://www.cjponyparts.com/ford-tir...valve-stem-style-set-of-four-2015/p/TBANDS5K/
I thought all we got was an idiot light? I have yet to see a full tire pressure display.
DickR
Raleigh
Go to gauges mode and scroll. The system normally doesn't respond immediately to pressure adjustments until you drive a bit.
Tim Hilliard
Happy Owner
Boston
'15 Guard 300A PP Recaro
I like the feature because I can monitor the pressures during a track session. They are plenty accurate for my purposes, stock suspension stock tires. I adjust pressures with a gauge (lowering them throughout the day) and the cars pressures are usually with in a pound of a gauge. Handy trend data, you can see what the delta is during a session and what the peak is as you come off before it has time to cool. Like others said nice having a warning before you enter a turn and get a bad surprise. For Drag Racing I understand not running them. I'm also 99% sure the TPMS has zero effect on performance.
Grintch
Hunstville
2015 GT PP
Which would seem to make it useless for #2.
onosqv
So Cal
QV
'15 Mustang
Not that OP needs TPMS, but for anyone else considering getting sensors for their other wheels:
Even cheaper from one of the other sponsors on the forum: http://www.levittownfordsupercenter.com/ford-racing-wheel-mustang-tpms-sensor-p-3515.html
4 for ~$62 shipped for my zip code. Might be able to get even cheaper from closer dealers (they seem to be selling for about $12/sensor from another dealer I just looked up online as well).
DickR
Raleigh
I was referring to the display's response to making a pressure change while parked. It won't usually respond until you drive a relatively short distance. It quickly responds as tires heat even in normal driving.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
my winter wheels dont have then and it just causes a light, i would have gotten them but were back ordered at the time.
Niz55
Us
17 GT350
You probably won't be able to turn off traction control.
RSKTAKR
kansas city missouri
2015 Mustang GT
I have had my stock rears (with TPMS sensors removed for about a month. The only that ever happens is that after driving around for a while the idiot light comes on. I have not felt any difference in the car performance wise, I turn ALL the advancetrac off before driving anywhere to. however, my car sits in my garage where I also happen to have the stock wheels/tires (that have the TPMS's in them) so the car sits close to the sensors most of the time, and then the light just comes on when the car is away from the garage long/far enough.
Mikeg4572
Mikeg4572
Scottsdale, Arizona
2015 Magnetic GTPP
Thats all I wanted to know. I just wanted to have a set of drag tires and not have them effect anything. I can certainly deal with the warning light on those very few days I go to the track.
thanks!
DickR
Raleigh
The service manual does not indicate that a TPMS failure disables any other function or setting. It apparently only displays warnings.
FYI regarding sensor update rates I found this when research this topic:
Each of the 4 TPMS sensors contain a battery, a tire pressure sensor and a radio transmitter. The TPMS sensor radio transmissions are sent approximately once every 60 seconds when the vehicle speed exceeds 32.2 km/h (20 mph).
