Apple car play does not work Mustang gt 2016
Food847
usa
na
I changed the usb hub and updated the software to version 3.0. When I plug my phone in the lighting cable nothing happens. Any recommendations?
Sound Wave
Honolulu, Hawaii
Gary
2015 GT 50th Anniversary Limited Edition MT
Maybe try inserting a USB music device to see if you can play music off of that. If so, try using a different lightning cable to see if that works.
Possibly do a soft reset or if that doesn't work, a master reset on the Sync 3. Good luck.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
This might be a dumb question... Do you have the CarPlay app installed on your phone?
I know people who have tried to use Android Auto on the car without having installed it on their phone.
I know there is also a switch in the settings screen to enable as well. Did you turn that on?
Mustangfreek
Pnw
15’ GT
Me , no.
It was more so to check out/remind me to try the reset feature.
Ya I don’t have “airplay” in base 15’s ;(
Bikeman315
Myrtle Beach, SC
Ira
Cathul
Germany
Peter
Ford Mustang GT
CarPlay comes standard on all iPhones. No need to install it after setting it up. You just need to accept the connection the very first time you connect your phone to your headunit.
Bikeman315
Myrtle Beach, SC
Ira
True. The only setup required is if you have wireless CarPlay.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Ah, ok. I wasn't sure. Never used an iPhone.
GR11M
Herts, England
Graham
Ford Mustang GT
Apple products are usually designed for idiots, so I'm going to say there's a problem with the usb hub. Are you using the usb ports in the arm rest and is the usb in the dash connected ? And what's a lighting cable ?
2016 Mustang GT PP
you need an upgraded usb hub on the 16s to support carplay
Cathul
Germany
Peter
Ford Mustang GT
Ok, can you use the Sync3 media player to access the playlists and music content on the iPhone? If yes, we know that the cable/hub is working.
if this is the case you need to check if CarPlay is enabled in the iPhone.
Settings —> General —> CarPlay
2016 Mustang GT PP
Yeah, what are your current Carplay Settings? You're connecting with a cable, yes?
