Youngmustang
On average how much would the installation cost at a shop?
I have the EU headlights and can say they just had to add the DD LED boards and driver/controller that comes with it. Then I tapped into the turn signal for the amber and a constant power source for the drl/rgb.Thanks Nick, other than questions Waldo Jeffers asked some time ago, I'd like to know if we europeans can use these multicolors led boards in our headlights without other mod. I know that we should get power from some other wires because we haven't the regulard led drl (and our drls power off when lights are on), but do our lights have all the parts inside?
I'm referring to the white diffuser in particular.. is that the same as US version and we could mount these boards without problems?
Unfortunately we don't have access to EU Mustangs, so we can't confirm that the internal components or design of the headlight will be the same.
With that being said, I don't foresee any reason why our RGBW or RGBWA replacement boards wouldn't be compatible with the EU headlight housings.
They can be wired up a variety of ways, but to achieve the sequential function you will have to tap into the factory turn signal locations.
Nick C.
Thanks Nick and thanks stoli! This is an important info for us.. now we can buy this wonderful kitI have the EU headlights and can say they just had to add the DD LED boards and driver/controller that comes with it. Then I tapped into the turn signal for the amber and a constant power source for the drl/rgb.
Speaking of the EU lights, does anyone know if the US lights also contain the leveling motor? We have the fuse for it (#68 under the hood).They are what The Lighting Firm used for their group buy (there is a post somewhere in the forum) You are right though, there is nothing beneficial about them. I upgraded the projectors and ballasts as well as adding the tri-bar from Diode.
No - there's a separate plug on the EU lights where the adjusters are on the US ones.
20% off this next couple of days!Is there any kind of forum discount or code with DD?
