Anyone Have Leftover Header Bolts?
Bonedizzle
Omaha, NE
2020 Mustang GT Base
Adding headers soon and since I (like many) am going to try and reuse as many studs as possible, just seeing if anyone has any locking header bolts left over from their install that they would be willing to sell cheap.
Don't really want to shell out $90 for a bunch of bolts that I am not going to use is all.
Craig Brown
Minnesota
Craig
2015 GT mustang pp
what type of headers are you putting on? I ask because I put on Stainless Power LTH and I didn't have to remove any studs. I was able to fit the headers on with all the studs in place. My car is a 2015 not a 2020 so I don't know what changes Ford may have made. I have all my bolts from the Stainless Power headers.
Bonedizzle
Omaha, NE
they are the cheap ones, so I am expecting to have to use some bolts. and I would rather have them on hand instead of waiting.
What would you want for the leftover bolts? they would need to be the correct m10x1.25 pitch (i read somewhere that stainless power ships both the 1.5 and 1.25 bolts out, but not sure if that is always the case)
Craig Brown
Minnesota
Craig
2015 GT mustang pp
I will give you a heads up when you remove the engine mounts don't lift the engine to high, or you can break off the vacuum actuator electrical connecter on the intake manifold. I will check out what they gave me and let you know. It will be cheap.
Bonedizzle
Omaha, NE
thanks for the tip, ill watch out for that. let me know your findings.
