Anyone else on this forum has the Gen3 SC Aluminator short block 9.5:1?
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
I tried using the search function and its coming up with no results. I have one currently being installed. How is it running ? Who tuned it?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
With the 9.5:1 CR, it will feel a little doggy until the boost starts cranking in. Just be aware. Dyno #'s will be 50-70whp less than a 12:1 boosted setup with similar parts/tune etc.
engineermike
La
2018 GTPP A10
Hey Cory, he's on a gen2 so it's dropping from 11 not 12.
Also, if the tuner knows how to calibrate the torque-to-load and load-to-torque tables then there will be no difference in part-throttle torque response.
There are at least a couple of gen3 9.5/1 aluminator dyno results on youtube if you care to check them out.
Cory S
Bradford, NH
Cory
Well, since most people focus on that big dyno number, it was just a warning mostly.
engineermike
La
2018 GTPP A10
Without a doubt, lowering compression reduces efficiency of the combination. So, in order to make up for it, the boost will need to be increased. Dropping from 11 to 9.5 will lose on the order of 40 hp, so I believe and additional 2 psi will make that back up. You'll find you can run a good bit more timing as well, before knock sets in.
