TheLion70x77
A3/B4 would provide similar bearing protection to SAE 50 or 60 weight (HTHS of 3.7). But the question remains, can they provide a lower viscosity at 100C than 50 or 60 weight? Those grades have substantially increased drag in the valve train during normal use as they are in the 16 to 21 cSt range at 100C.
The best solution is still a thermostat controlled Air to Oil cooler running 5W-20 or 5W-30. Every 20F increase in temp drops you one viscosity grade on average with the exception of 20 to 30, which is about a 30F step. 5W-20 running at 210F will provide the same film strength as 5W-50 at 280F.
it's all about temperature. Also to maximize wheel power, you need to heat up the 5W-50, as it thins out your power to the wheels will increase, so you'd need some warm up laps.
The other downside of using a higher viscosity at elevated temps other than needing to warm up to achieve maximum power is that the oil will break down much faster. A lower viscosity oil at more ideal temps will out last a higher viscosity oil at elevated temps.
But yah, if your running frequently at elevated temps, a 5W-30 will offer very slightly increased bearing protection. Not sure if it's necessary however. If your not making metal on metal contact under worst case conditions for 5W-20, 5W-30 will offer no benefit.
