Any tips for replacing o2 sensors?
mookieit
tampa
john
mustang 2015 v6
Today I planned to replace all my o2 sensors.
Started on the passenger side, after lot of effort, I was able to replace the downstream sensor as I guess the sensor was kind of seized after 123K miles.
I could not for the life of me remove the upstream sensor, the area was kind of tight and could not remove it.
I used a dedicated O2 sensor wrench, white didnt help much, then what worked was a 18” extended ratchet with a o2 sensor wrench from Harbor freight.
So I got 3 more sensors to remove and planning to use some penetration oil and a 22mm wrench with a 15” extender. Not sure if it would work.
Was wondering what if you can share any tips that will help me through this process
