Answer if you can , problem with a 2015 GT
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
2015 GT M6 355 gears stock tires
I was at the track tonight and had a very strange thing happen ...If I left at anything up to and over ( 3000 to 3500 ) the car would come out of the hole hard for about 30 feet then the car would fall on it's face and rev really really slow all the though first gear right to red line .It felt like someone just flipped switch and turned off the power in first gear ...As soon as I hit second gear the car would haul ass ..It felt like the T/C was on but it was OFF ..It was like you had the brakes on in first gear . It would bog down almost to idle and then rev up so so slow it felt like you were pulling a 10,000 pound trailer behind you ..As soon as I shifted to second gear it would wheel hop and grab and haul ass . The only way I could stop the power loss was to leave at idle and then floor it and then it would haul butt in first gear.. When it would lose power in first gear it would run high 14.90s @ 108... Leaving at idle it ran a 12.78 @ 112.30 ...Any RPM higher on the launch it was back to high 14s .. It felt like someone stuffed a rag in the throttle body after the first 30 feet ..
Has anyone else had this problem ? I going to add drag radials shorty and leave at a much higher RPM to get the 60 footer lower ..But I'm worried it will bog like it did with the street tires. There was a bunch of new 2015 GT M6 there and if the left hard they would just blow the tires off , they watched my car leave hard for a few feet and they say it sounded like I just let off the throttle .. I can assure you I had it to the mat every time . :shrug:
cbrtrx
tampa fl
2016 mustang gt
Clutch protection strategy kicking in, although everyone on here will say its your traction control.
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
Thats a pretty good time... 12s... Got a friend who had the same mods on stock pirellis ran 14s...
maybe the tune??
smokinzx14r
smokinzx14r
ST Petersburg FL
Lee
Hummm ... I was smelling burnt clutch when this happened ...What is clutch protection strategy ? How does it work and can I get rid of it ? when ever this happened I could feel the clutch peddle drop a few inches after I fully released it ..
Thanks Lee..
smokinzx14r
smokinzx14r
ST Petersburg FL
Lee
maybe the tune??
I don't think it's the tune , I had it happen twice last week before I put the Bama tune in ...
cbrtrx
tampa fl
2016 mustang gt
Its in the tune, it can be disabled. It limits power when it detects any excessive clutch slipping, thats why when you dont slip the clutch much it will give all the power.
smokinzx14r
smokinzx14r
ST Petersburg FL
Lee
Ok ...Sound good ... I'll give Bama a call about this and see if they can turn it off ....Thank you ..:thumbsup:
BoomBoy
Racer
MI
Kenny
2017 Shelby GT350, 2016 Fiesta ST
Clutch slippage protection. I like it. It protects your clutch. Why would you want to turn it off and destroy your clutch?
cbrtrx
tampa fl
2016 mustang gt
So you can launch your car without it killing power. If you know how to drive you wont have any clutch problems from disabling it.
rio16
MAD_50HH
Bay Area SJ, CA
Rio
Yea i had the same issue with my old coyote.. hopefully its just the tune.. good luck brotha.. you should start selling the DRIVER MOD around here jk.. wish i could do 12s..
65ffr
'04 Ram 1500, '65 FFR Cobra
Thanks Lee..
Are you saying the car can depress the clutch pedal by itself? I don't think that's possible, even if it were it would cause more slippage....
smokinzx14r
smokinzx14r
ST Petersburg FL
Lee
Not saying that happened , but that is what my foot felt right when the motor nosed over ..I could feel the peddle move down about 2 inches or so when the power cut out ..:shrug:
15guardGT
Rockingham, NC
2015 Guard Green Auto GT
No, clutch protection pulls engine power, limiting the torque output.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
As others have said it is either the clutch protection or traction control. When you turn off the traction control are you holding it off for 7 seconds?
15guardGT
Rockingham, NC
This is the table
