Another PMAS No-Tune Dyno Result!
shelbydave
springtown tx
2017 shelby gt350
I'm calling them tomorrow
Cheapest place to buy??
Amaury
Amaury
Puerto Rico
na
I got mine from Lethal
GA
For what it's worth it made more power on the rich run which was with the Pmas intake.
No. Look again. Run #1 is the PMAS run. Its highest AFR is 14.6. Observe where the AFR lines start and trace the one that starts at 14.6.
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
Well that'd be deceptive if the gains came from leaning out the AFR rather than the intake itself.
aham23
FPC 5.2
Phoenix
22 FJG Mach 1 w/ HP
wait for lethal performance and their 12 days of Christmas sale. thinking it will be 20% off. check their site out.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
The PCM controls the afr and changes injection quantities based on available air and torque demand. I'm not sure why there's a significant difference in the afr between runs, though. The intake wouldn't do it by itself, because the PCM will try to maintain its targets.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
It's in cat overtemp on the first run. Car was hot when they did that pull.
cbrtrx
tampa fl
2016 mustang gt
Looks like cat over temp was on both pulls which is normal on the stock tune.
cbrtrx
tampa fl
2016 mustang gt
Once it's tuned and cat overtemp is off it will be more consistent on the A/F.
Yes I know this, I was just explaining how you said it was the cat over temp affecting the a/f but it was clearly on both pulls.
Terminator2
Spring Hill Florida
David
The pull at 12.3 to 11.6ish a/f it's not on on that run the PE lambda drops from 0.85 to 0.82 right there. It might be just beginning close to redline on that pull but it's close to normal there.
cbrtrx
tampa fl
2016 mustang gt
Cat over temp enrichment was recorded on both pulls. You said it was not, I'm just clarifying that it was also as already mentioned the one pull was leaner then the other.
