After Whipple Install code P2096
sonic
NY
Prius
This was the only test in the pin point. Basically it looks to me as a bad connection. I hate extensions for that reason. double check your connections make sure none off the pins got bent or pushed out in the connector
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Thanks sonic, I'll check them all, just so I'm seeing this right, bank 1 should be passenger side correct?
Stage_3
MA
2019 Roush Stage 3
So I went out and checked everything, went over all connections, unpluged and replugged O2 sensors and still nothing. For whatever reason I could not get the codes to clear, even the de-energizing code? So I reflashed and finally got the code to clear, the weather is terrible here so I didn't get to drive it but I let it sit in the garage for about 20 minutes and the code hasn't came back on as of yet. I'll see what happens next time I get to drive it I guess.
Good luck Brandon!
zaquhree
Orlando
2015 S550 GT
You shouldn't need the extensions, unclip the harness from the trans...
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
I got the code to clear, checked all my connections and cleaned them all. I drove it to work last night and back today and so far so good, it still hasn't returned. Im starting to think it may have sensed something was off when I drove it to the exhaust shop with open headers and it didn't really know what was going on or thought there was an exhaust leak. When i drove it over there, I had my x-pipe just slightly tucked into the collectors on the header so maybe thats what caused it.
sonic
NY
Prius
:cheers:
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Just wanted to update and throw up a picture!! Got about 100 miles on the car since I got the code to clear and rechecked everything and the code hasn't come back. So thank everyone for the support and help!! Did a little photo op today also!
Whipple SC
Fresno
Those are some mighty sexy photos, you mind if I use them?
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Dam...that's TIGHT!:eyebulge:
sonic
NY
Prius
Love the wheels! What are they?
bmoore1488
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Stage_3
MA
2019 Roush Stage 3
I'm more than positive this was the case! Glad it's resolved for you.
Good luck.
Car looks killer too! Very nice. :thumbsup:
