Whipple P2096
dmxxcy
Long Island NY
2016 GT
So i filled my car up and then put it away for about a week then i went to drive it the other day and it stalled 3 times. On the 4th try it finally leveled off and started and was fine until about 10 miles into my drive i threw a p2096 code.
I cleared it to see if it would come back and in about 2 more drive cycles it came back again. Today i went to run my car and it almost stalled again on start up but it eventually was fine. Im starting to think i got a bad batch of gas. Hoping to run it down and fill up again and everything is okay.
Has anyone had this code or type of issue?
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Post catalyst fuel trim system too lean bank 1.
symptoms:
Rough idle, Poor fuel economy, Poor acceleration, Misfire, high catalytic converter temps, Possible spark knock (detonation / pre-ignition)
Possible causes:
Low fuel pressure caused by a clogged filter, failing fuel pump, failed fuel pressure regulator or clogged or leaking injectors.
A large vacuum leak
air leak in exhaust at or near the bank 1 rear o2 sensor
plugged catalytic convertor
failed o2 sensor or failed MAF sensor
dmxxcy
dmxxcy
Long Island NY
2016 GT
This happened right after i installed defoulers wondering if my car just doesn't like the defoulers. I also had someone with a vmp have the same code and they said it was most likely bad gas because they had run their tank down and refilled with new gas and the light has not returned.
markmurfie
Hawaii
Mark
Defoulers can cause it. Not sure they would cause the stalling issue. Did you delete the cats? Ditch the defoulers and look into sensors simulators from URD. Or just get your tuner to delete the rear sensors in the tune if passing emissions are not a concern.
