Aeromotive Flexfuel Sensor Adapter Tech- Beefcake Racing!
beefcake
Bethel
2018 Ford Mustang
The guys at Aeromotive stopped by the shop last week and gave us a break down of how the NEW-ish Aeromotive Flexfuel Sensor Adapter works. So i wanted to put a post up about it.
Allows for the use of an Ethanol Sensor (Flexfuel Sensor) to determine the percentage of ethanol in fuel
It is designed to work in tandem with the restrictive OEM Flex Fuel Sensor to help measure ethanol content while keeping fuel moving through your system. The adapter has ORB-10 inlets and outlets that can be adapted to any size fuel line and works with these OE part numbers - 13577429, 13577379, and 13577394.
• OEM Sensor is Restrictive for Fuel Systems that Flow Greater than 400lph
• The Adapter Allows for Higher Flow Rate as it Creates an Alternative Route for the Fuel to take While Still Using the Sensor to Monitor the Ethanol Content
• Dual O-Ring Sealing on Tubing of the Flexfuel Sensor
• ORB -10 Inlet/Outlet Ports that can be Adapted to any Fuel Line Size
• Adapter Body Constructed from 6061-T6 Aluminum Alloy with Bright Dip Anodize Finish
Video -
Purchase Here: https://www.beefcakeracing.com/aeromotive-flex-fuel-an-10-sensor-adapter-15141/
Please call or email with any questions!!!! 855-827-7223 or [email protected]
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
So not for Musang applications I take it ?
beefcake
beefcake
Bethel
2018 Ford Mustang
It's designed as a universal adapters so it can be used with any application; would just need the appropriate -10 ORB fittings, or line size adapters. Would also need the Flexfuel sensor; OE part numbers - 13577429, 13577379, and 13577394 will work. They are a GM sensor but can be used for Ethanol content gauges ect.
Like the Innovate Motorsports MTX-D Ethanol Content Percentage & Fuel Temp Gauge Kit 3904
https://www.beefcakeracing.com/innovate-3904/
Jeepwx03
PA
68 Mustang, 15 Mustang GT PP, 13 F150 FX4
I've been looking for decent gauge pods for the S550 to mount something like this. Maybe it's just me but I'm not finding much other than the A piler, it really makes me wish we had some better options out there.
silverbullet85
San Diego
2019 Gt
Motion raceworks has had this for at least 6 months
beefcake
beefcake
Bethel
2018 Ford Mustang
We use the Innovate Motorsports gauge and sensor kit. its your standard 2-1/16 gauge. One of my sales guys slightly modified the center vent on the dash and installed his there. But most do use the Auto meter a pillar. They make a single gauge or dual gauge mount.
Innovate Gauge kit- https://www.beefcakeracing.com/innovate-3904/
Single- https://www.beefcakeracing.com/autometer-12135/
Dual- https://www.beefcakeracing.com/autometer-12136/
