AED S550 Knuckles Exclusive at TBR
beefcake
Bethel
2018 Ford Mustang
Who wants to run up to a 15x12.5" wheel on their S550!!! Now you can, the new AED 15-19 Knuckles now available exclusively at Team Beefcake Racing.
Limited Supply available!
AED Rear IRS Knuckle fits 15x12 Wheel (15-19 Mustang) * In Stock!
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Is this meant more for drag racing? What are the benefits other than wheel fitment?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Yes, and probably lighter weight too. Here is the product description:
The AED rear IRS Knuckle is a replacement knuckle to allow a wider wheel and still maintain the factory suspension geometry. Re-Uses mainly stock components including factory wheel, hub, brake caliper, brake line, sway bar, toe link, lower control arm etc...
To build such an integral suspension piece, we start from an 82lb chunk of billet aluminum and machine it down to about 6lbs. This weight to strength ratio will support anything from stock horsepower to 1000+ with the security of knowing you have a premium component that will not fail at the track. Aurora Race Series 12T and 10T bearings are used for exceptional load capacity for the toe and main unit. Machined helicals for the caliper mounts while Timken steel spacers allow use of the stock caliper.
A lot more to it than just swapping the knuckle, but it seems like this is for the hardcore drag guys that have drag brake kits and also do everything they can to win their brackets.
Slater_5.0
Denton, TX
Derek
2019 Cali, 2016 GT premium
What else is needed to run these? The way you are describing them, you just throw these on and run 15's and I find that hard to believe.
Nagare
Ft Lauderdale
I don't get why vendors aren't allowed to at least link to the product page on these announcement posts, would clear up questions for everyone that can't google:
All billet IRS Knuckle allows up to a 15x12 wheel on stock rear suspension. Standard OEM knuckle only allows up to a 15x9 and requires a custom offset. Fitment for all 2015-2019 Mustang GT, V6 and Ecoboost.
Features & Benefits
• Anodized Black T6061 Billet
• Made in USA
• Premium Installation Hardware
• ARP Nuts and Washers
• Fits Stock S550 Wheels or up to 15x12
• Use Stock S550 Hub and S550 Brake Caliper
• Re-Use Stock Spindle and ABS Mount
• No Change in Rear Geometry
• No Bleeding of Rear Brakes Required
• Fits Aftermarket 5-1/4" / 5.25" Brakes (See Specs Below)
• Use Stock S197 Mustang Rotor
• Stock to 1000+HP Capability
• Sold as a Pair
Brake Mounting Info
- Fits Stock S550 Caliper but must use a S197 Brake Rotor (purchased separately)
- Machining is required to fit the Rotor to the Hub, easy with die grinder.
- Dual Mounting location fits stock S550 Caliper or aftermarket calipers with 5-1/4" spacing like Baer, Lamb, Aerospace, Wilwood etc..
- Center of Spindle to Top Caliper Bolt Hole is 4.552" or 115.5mm
- Hat Depth Hub to Caliper is 2-13/16" or 71.5mm
Installation Notes
- Modifications to sway bar end link bolts, factory toe link and lower control arms are required for proper wheel clearance
- We suggest an alignment when complete to make sure everything is lined up correctly
beefcake
beefcake
Bethel
2018 Ford Mustang
we have a nice video on the item page
beefcake
beefcake
Bethel
2018 Ford Mustang
they are running a 15x11.5 beadlock which measrues, 15x12.5, we are running a 15x11" beadlock which measure 15x12 on our car. we just finihsed up a new part # with baer today as well. so you can run your oem brake calipers with s197 rotors, or baer now has an offering specific to our knuckle kit
mbusch84
Youngstown Ohio
Triple yellow 15
Any pictures of your guys setup wheel/tire on car? What backspacing are you running?
beefcake
beefcake
Bethel
2018 Ford Mustang
ask and ye shall receive. backspace is 15x8.75, but we needed a small spacer, as they shorted me on the back pad a little bit, so about 8.5 on my car, new wheels would be 8.75 if your ordering
and, the beautiful thing is, i'm running a +.2 camber, vs the 15x9 setups where you have to run a -1 to -1.5 to get the wheel to not hit, so on launch, all the tire plants
