Adjusting Steeda Pro-Action Adjustable Dampers
Hadelson
Allentown, Pennsylvania
Hugo
24 RTR Spec 3
Just received set of Front and Rear Steeda Pro-Action Adjustable Dampers. Setting them up for install - Instructions say turn dampers all the way clockwise to full soft position and then back out one full turn as starting point.
Question: Does the damper have a fixed stop when turning all the way in Clockwise?
Anyone have feedback-experience with this?
Thanks
Hugo
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Thanks
Hugo
Turn the adjuster clockwise on front and rear until they stop. Then turn 1/4 turn counterclockwise from soft as a starting point. You can tell a difference in quarter turn adjustments at a time.
This is by experience, I have tracked these dampers for the last two years with outstanding results! I will have the team change the instructions to 1/4 turn off soft.
Steeda Tech
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
If, as I suspect, they're anything like Konis, you'll feel an increase in resistance to turning the adjuster. Don't try to force it any further in an attempt to find a hard stop. Same would apply to the full firm end of the adjustment range.
Norm
