Adding OEM Rain Sensing Wipers
Tampa, FL
2017 Mustang Eco Premium
Literally you can wire over to your kick panel fuse box and connect the power wire to a switched fuse.
True, but have to get through the firewall for a future project, so still kinda interested in what OP did. But any specific one you would recommend? Looking at a diagram for the fuses, the best one I would guess is 23 for the powered mirrors, but I'm not the best with electrical wiring, so completely open to anyone's thoughts on that.
http://www.fordservicecontent.com/F...ang-Owners-Manual-version-1_om_EN_07_2015.pdf
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
I did the same as the op as well. I went through where the sound tube used to connect behind the accelerator pedal. If you still have your sound tube then that won’t work either.
Tampa, FL
Don't think ecoboosts have the sound tube, pretty sure that was only for the GT, and eco owners got screwed with the "augmented sound" option where fake noise is played through the speakers if enabled. I can look to see if there is a cutout for it, but pretty sure the tube itself isn't there. I might be mistaken though
Tampa, FL
Well, I'm not sure what the problem would be now, I have everything installed and power going to the sensor, code changed in forscan, but the sensor doesn't seem to work. In the Int setting, the wipers just work like they used to, without any water on the windshield. And this is after enabling and even disabling the setting in the IPC. Kinda confused as to what the problem might be with this.
BarberStang
Chattanooga,TN
Mitchell
2019 Mustang GT (base,6Spd,BAP)
Has anyone figured out how to add Blis? I know you need the mirrors and bumper sensors along with maybe a harness. Anyone know how/part numbers?
RogueFive
Middle Georgia
Nathan
2015 Mustang GT Premium
I followed the instructions and this worked PERFECTLY. Thank you, OP!
For power, I tapped into the yellow-brown wire that goes into the same connectoron the new harness - its accessory power for the auto-dimming mirror. Only the LIN wire needed to be run anywhere.
manvir1212
london ontario
manvir
2020 mustang gt pp2
Hey looking to add this into my 2020 mustang I just need the sensor and cover I’m confused on the wiring. Does anyone know the part number for it ?
