I hate to disappoint you but the wiring for memory seats is different than non memory seats. There is a memory module that sits under the driver seat, check if you have it? If yes, then you can probably just run the wiring between the different modules. I attached the high-level power diagrams and detailed diagram (including the data lines).So on a whim I searched eBay for a memory switch. Found a door handle with the lock buttons and memory switch for very cheap. Paid about $26. When it arrives I will remove the door panel and see if the plug will fit. If it does I will plug it in, cross my fingers, and hope it will work. But I know it won't be that easy. Hoping Ford uses a universal harness instead of car specific ones. We shall see
Don
Hello Don,So on a whim I searched eBay for a memory switch. Found a door handle with the lock buttons and memory switch for very cheap. Paid about $26. When it arrives I will remove the door panel and see if the plug will fit. If it does I will plug it in, cross my fingers, and hope it will work. But I know it won't be that easy. Hoping Ford uses a universal harness instead of car specific ones. We shall see
Don
Big plug that disappears under the rug | ||||||||||||||||||
C340 | Color | |||||||||||||||||
1 | VIO/RED | +VDC (30A fuse 12 BJB) (electric seat and memory module - DSM) 14 AWG pin is on connector edge) | ||||||||||||||||
2* | BLU/RED | +VDC (7.5A fuse 2 BCM) (memory module) I used yellow 16 AWG | ||||||||||||||||
3 | GRN/BLU | seat belt sensor | ||||||||||||||||
4 | YEL/VIO | seat position sensor | ||||||||||||||||
5* | GRY/ORG | MS CAN + (for memory module - DSM) 20 AWG. I used blue | (could add wire to OBDII connector (DLC or gateway module pin 23 (GRY). Also C210 pin 17 both GRY | C210 is a 20-pin black connector by driver side kick panel | ||||||||||||||
6* | VIO/ORG | MS CAN - (for memory module - DSM) 20 AWG. I used white | (could add wire to OBDII connector (DLC or gateway module pin 22 (VIO). Also C210 pin 18 both VIO | C210 is a 20-pin black connector by driver side kick panel | ||||||||||||||
7 | BLK | seat belt and seat position sensor return | ||||||||||||||||
8 | BLK or BLK/GRY | ground (electric seat and memory module - DSM) 14 AWG (pin is on connector edge) | ||||||||||||||||
9 | on connector edge) | |||||||||||||||||
10 | | |||||||||||||||||
11* | BLK | ground for memory module - DSM) ? AWG. I used 16 AWG black | ||||||||||||||||
12 | GRN/BLU | lower side airbag feed | ||||||||||||||||
13 | GRY/YEL | lower side airbag return | ||||||||||||||||
14 | BRN/BLU | upper (curtain) side airbag feed | ||||||||||||||||
15 | BLU/GRN | upper (curtain) side airbag return | ||||||||||||||||
16 | on connector edge) | |||||||||||||||||
*Add |
