krt22
It is??Something also to consider..
The Corvette is seen as a status symbol, the Mustang, no matter what variant, is not.
Every car with FI has a problem with heat soak. Even MINIs warp their hood scoops because they get so hot.Chevy needs to admit they have a cooling problem aka heat soak.
people experience the heat soak after a few WOT pulls on the highway for races. There are videos of a c7 z06 racing a viper ta. After a few races it started losing worse after a few pulls because it started heat soaking. From what I gathered last time I was on the vette boards, it had a tune issue too, that it would pull timing. A tune seemed to fix that issue but the heat soak still seems to be a problemChevy needs to admit they have a cooling problem aka heat soak. It doesn't take a track to experience heat soak. Chevy simply saying they programmed it to go into limp mode once the internal temperatures were exceeded is not acknowledging the root cause. Bottom line it needs a better heat exchanger for the Eaton super charger. If I had spent 100K (loaded)on one I would be really pissed off. Clearly some have not experienced the issue but seems to be the exception to the norm.
At the end of the day I am sure the execs are questioning in private why they went FI on their new track monster. FI simply creates an amazing amount of heat which causes so many more issues than just limp mode such as engine longevity. I am not fully up to speed on all the issues but I have read of several failures as well with I am sure heat being a contributing factor.
Didn't know about the '13-14, so I stand corrected. And with emissions controls and packaging being so tight nowadays, heat soak is a fact of life for a lot of cars - my C6 (not FI) used to get so hot under-hood, I was afraid it would blow - but it never did.Not exactly true. It is difficult to get heat soak issues in a '13-14 GT500 as Ford did a nice job with their H/E and pump configuration. I would say they learned from earlier models as they would heat soak bad. I installed a C&R heat exchanger in addition to a larger blower at 740 rwhp and ZERO heat soak. The problem can be solved. OEM's seem to overlook the volumetric efficiency part of the equation when it comes to FI.
The 2014 gt500 I sold, had heat soak issues, while not nearly as bad as the z06, it still had problems. Stock it heat soaked, full bolt ons it soaked.Not exactly true. It is difficult to get heat soak issues in a '13-14 GT500 as Ford did a nice job with their H/E and pump configuration. I would say they learned from earlier models as they would heat soak bad. I installed a C&R heat exchanger in addition to a larger blower at 740 rwhp and ZERO heat soak. The problem can be solved. OEM's seem to overlook the volumetric efficiency part of the equation when it comes to FI.
Sure you can increase the temp thresholds in the tune but it still doesn't fix the root cause for which the m'fr has determined is the safe operating temp thresholds. The Ford tune would pull wicked timing in a heat soak condition all in efforts to save the motor. Any responsible tuner IMO would not remove those failsafes. They are there because heat causes detonation among other problems which all translates to a melted piston, blown motor etc. If I had one the first mod would be is to replace the factory H/E. I would think the aftermarket has addressed that such as C&R or AFCO.people experience the heat soak after a few WOT pulls on the highway for races. There are videos of a c7 z06 racing a viper ta. After a few races it started losing worse after a few pulls because it. The factory tune just pulls timing. I haven't seen any reported problems after a tune. From what I gathered last time I was on the vette boards, it was tune related.
I never said it couldn't but any mods an upgraded H/E should be first on the list.The 2014 gt500 I sold, had heat soak issues, while not nearly as bad as the z06, it still had problems. Stock it heat soaked, full bolt ons it soaked.
you missed my edit.
Maybe this is true in some areas of the country, but even owning a couple year old GT I took some crap over it. "Wow, nice car! You must be making too much money!" IMO that's especially true of the Shelby cars. A guy I know seems to be talking to me a lot less since I've been considering the Shelby. Jealousy? I don't know but I've gotten the impression he thinks I have too much money. I don't even own one yet! Part of the reason I'm getting black and no stripes to not call so much attention to myself (that's if I'm able to get one).The Corvette is seen as a status symbol, the Mustang, no matter what variant, is not.
I know you didn't, you said it was hard. I was just disagreeing, that it was pretty easy. :cheers:Sure you can increase the temp thresholds in the tune but it still doesn't fix the root cause for which the m'fr has determined is the safe operating temp thresholds. The Ford tune would pull wicked timing in a heat soak condition all in efforts to save the motor. Any responsible tuner IMO would not remove those failsafes. They are there because heat causes detonation among other problems which all translates to a melted piston, blown motor etc. If I had one the first mod would be is to replace the factory H/E. I would think the aftermarket has addressed that such as C&R or AFCO.
Motor trend is also in gm's pocket, theyre paid to make the corvette look good, not to elaborate about a glaring overheating issue.
