AC Vent Odor
blipszyc
Charlotte
So I'm rounding year 3 on my Mustang and for the first time, I'm starting to get a mildew smell out of the AC vents. I've done a couple things like run the heat for a few minutes or just the fan, which helps for a couple days but then the odor comes back. I think this is due to the extraordinarily warm February we had here in the south and the use of AC for a week or so and then back to heat.
I have a can of spray cleaner for AC units that I think will work, but I have no idea where to use it. Where is the condenser unit, and is that the right place to spray? Or should I just spray into the vents themselves?
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
My 2010 was full of water at what I call the wink valve against firewall. Over times leaves debris clogs it up so check that if the newer cars still have that valve
bigriver
CA
2019 Ram 1500 Laramie
I have that from time to time and disengage the recirculate button so fresh air comes in.
antny825
Mass
Tony
2016 GTPP
Have you changed the cabin air filter? Sometimes that helps with the mildew smell.
x_man586
Thank you Diatoms
Marshall Texas
2016 Oxford White Mustang GT m6
I always figured that if I kept the cabin filter clean it wouldn’t smell. But I have a brand new one in and it smells bad whenever I turn off the compressor.
melwff
Danbury,CT
2021 Mach 1 M2486
remove the cabin air filter and use lysol or a similar product. Make sure the evaporator drain isnt clogged preventing water from running out.
