2017 far left driver side AC vent?
jordystang69
NY
2017 Mustang GT Lightning Blue
The vent on the drivers side on the left near headlight selection dial doesnt seem to be blowing any air. Or if it is, it's a very small volume. Anyone else have this?
yomamma219
Raleigh, North Carolina
2016 Mustang EB Premium Pony Pack "4HORSEMEN"
Is it open? Also are you in the middle vent mode? Mine blows air the same time the middle circle vents blow air.
yomamma219
I think if you slide it all the way in one direction it reduces the opening a good bit. By middle mode I mean the vent selection. Do you have base stereo or upgraded? I believe on the base unit there is physical buttons to select when air is blown from. If it's an upgraded radio navigate to the climate control section of the touch screen and manually select all vent modes (feet, face, defrost, from bottom to top that's what they do same as in any car I know). Then manually turn the fan speed all the way up. If air is blowing out of the circle vents in the center of the dash than air should be blowing out of your problem vent.
jordystang69
jordystang69
NY
I see now. I should have looked closer. I Tried to direct the air towards me, but doing that almost closes that vent 100%. pretty stupid design. The air flow goes toward the window and not the driver.
