MCarsFan
I was in traffic for a total of 2.5 hours yesterday with the M5 (in Manhattan bumper to bumper).
- The car has 3 shift settings, 1,2, and 3. 1 is the least aggressive one and 3 is the most aggressive one. Aggressive being upshifting quickly and not downshifting easily. So in setting 1, it will upshift in 1500 rpm and hold the highest gear possible.
- The problem is, in setting 1, you got no power. None. Car is in borderline stalling territory. In setting 3, this thing never shifts to higher gear even in 4000 rpm causing extremely jerky driving.
- So as a result I use setting 2. This is what the car does: say I can only accelerate 100 yards before stopping again. It will go from first to second and then right away to third. At third, it has no torque. I slow down now it shifts down to 2nd and when I slow down further down back to first. So the entire fucking time it goes 1,2,3 and 3,2,1. Whereas in my mustang I would be in the first most of the time and only yse 2nd when I know for sure I will keep my speed higher for longer periods of time. The computer cannot read my mind and doesnt know that.
- There were cases where it went from 1 to 2 to 3, then I had to make a sudden lane change, but guess what because the idiotic transmission is on 3rd gear at 1100 rpm, i had no power. I could depress the pedal more resulting in a jerky quick shift. You see my point? Not smooth. A human driver would have never shifted to 3rd in this case. And would have held 2nd gear.
- I could use the manual mode but guess what because of the uber anti lag technology (which is amazing when you are WOT), this car above 1500 rpm has so much instant torque (all 516 ft/lb of it), a slight tap of the gas results in very jerky movement (not the case in the shelby).
The conclusion is naturally aspirated and manual transmission is far smoother combination. When technology gets involved and we humans start complicating things, we usually screw things up. Older is always better
