350R - rpm sputtering / floating
AgSurfer
Ohio
2020 Shelby GT350R / 2021 Shelby GT500
Was driving my 350R yesterday afternoon and experienced some RPM sputtering / floating in 4th and also 5th gear between say 2.5 - 3.0k RPMs. Was applying gentle pressure to the throttle and essentially maintaining cruising speed. I could feel the car chugging a bit when this happened, as the throttle response was far from clean.
It was also an extremely windy day in NE Ohio yesterday - wasn't sure if all that wind could have been messing up the intake, MAF sensor, etc.
I've also read this issue can be caused by inoperative cruise control system (for which there is a Ford TSB), vacuum leak, and some other potential causes.
Curious if anyone else has experienced this issue before.
Appreciate any input.
DaveB
Indiana
18 gt350, 16 gt/cs (wife)
I’m currently dealing with the same issue… I believe. I’ve got an 18 non-r. I tested my cruise, because I’ve never used it, and it is inop. The rpms hang up for a second, seems like forever, when I let off the clutch. It’s my daily driver so I haven’t really taken the time to check it out too much or take it to the dealer…. I am a mech at a hot rod shop and own my own performance and detail company, plus I don’t know that I trust the dealership?! I put my scanner on to see if there were any codes that possibly kicked without kicking the light, but there were none.
Reading the tsb that I saw, the fix is something about the tailshaft housing nuts on the trans backing off.? I wonder if there is a sensor or something there. I need to take the time to look🤷‍♂️
AgSurfer
AgSurfer
Ohio
Thanks Dave - this sounds very similar to my issue. I am also not throwing any codes. I rarely use cruise control, but did a couple times in the late fall and it was acting up... some times not even engaging. After a shut off and restart a few days later, cruise seemed to work ok but I did experience that odd rpm fluttering again.
Cars are in for their winter hibernation now, so I will be revisiting this in spring 2025.
T7TheLama
Austria
Philip
2016 GT350 Track Pack
Vehicle Speed Sensor maybe? (OSS Sensor)
wingnutt
@FL410
michael
350R Procharged w/P1X
Check that your air filter is snugly attached…mine was loose and had many of the same signs not long ago 😉
TonyNJ
Northern NJ
www.instagram.com
Tony
DaveB
Indiana
I’ll let you know what I find, when I get my self to check!!!
that’s the one I’m talking about! Thank you. If it’s loose I don’t know if it just needs tightened or if anything needs held while tightening
TonyNJ
Northern NJ
www.instagram.com
Tony
I feel something happening with my 350R around 3k rpm until about 4k but I'm not sure if that's just the magic kicking in.
DaveB
Indiana
Almost like a pulsation/ hesitation/surge? Almost like it’s struggling to get fuel for lack of better words?
TonyNJ
Northern NJ
www.instagram.com
Tony
It's a surge, not so much a pulsation. Almost like it's slipping then kicks in. Not sure if it's the voodoo power band kicking in or trans slipping or this output shaft issue. I need to get under the car and check it out.
526 HRSE
California
2017 GT350 Grabber Blue
Tone ring. Happened to the best of us.
526 HRSE
California
It's done for, so the only logical thing is to sell it to me.
Yes, the motor is about to blow. The depostitioning sensor fluid is out of balance causing the shortshiftaplex to misplace itself at high idle under 200 rpms. Very dangerous. Should get rid of the car immediately.
526 HRSE
California
Talliuz
Daniel
2019 Shelby GT350
Following this thread. I have had this issue on my 19 non R for the longest. The only reason I have not checked the tone ring is because it only happens after pulls. Very very rarely happens during normal driving
