3.55 gears make much difference over 3.31?
SVO MkII
IL
2018 Ecoboost, 6sp, PP, 2017 GT Convertible
3.31 and 3.55 are too close together to warrant an upgrade. Go with either 3.73 or 4.10 if doing an upgrade.
Yes, I agree 6th gear isn't usable in the 3.31 in normal driving. I had the 3.31 in my EBM and 6th gear felt good after 80 mph. But by 80 mph, you are in the danger zone.
6th is too tall even with the 3.55s. A properly spaced gear set will have closer ratios as you go up in gear, i.e., 5-6 should be closer than 1-2, etc. This helps to compensate for increased drag as the vehicle increases speed. The huge gap between 5-6 (1.00 to 0.70) is a blatant economy move. It should be something more like 0.85 for 6th. If I ever have to go into the gear box, I will install a shorter 6th.
  • Like
Reactions: Ebm
SVO MkII
IL
In what application? For competition or everyday driving? If you never used 6th gear for either of those applications what would you lose?
Certainly on the track, but even in everyday driving. Just winding up through the gears, shifting at 3-4K, it feels natural, until you shift from 5-6...huge drop. Also, I find myself having to shift back and forth a lot between 5-6 when I'm driving on the highway in traffic. If 6th was shorter, I'd be able to keep it in 6th and more comfortably accelerate from 60 to 80 as needed.
By comparison, I have a couple of older Porsches w/ 5sp, including a 944 Turbo. 5th is perfect in this car. I just get up to speed and use the throttle as needed.
justme97
justme97
Milford, CT
18 LB Ecoboost 6mt pony pack vert, 06 EB Explorer
I tried driving a little in 5th only and it seem to get almost 27 mpg and was pretty responsive. Is there any reason you couldn’t just leave it in 5th in congested highway driving and then pop it up 6 if nothing’s going on?
This threads been very informative, I think I’m going to just leave my 3.31 gears alone. The car could be a little more perky off the line but I never realized that shorter (taller?) gears could hurt my 0 to 60 by nessesitating an extra shit. More fuel efficient and better 0 to 60 seems like the best of both worlds. Except for the turbo lag :p
I usually don’t drive in sport because I don’t think throttle mapping (the equivalent of mashing the gas pedal correct?) is the answer to better performance..but I suppose it’s an option...
ElAviator72
Canby, OR
Brent
2016 Ecoboost PP Deep Impact Blue (base 100A car)
5th should be a mild overdrive (like it is in most other 6 speeds...), something like 0.97:1. Just my 2 cents.
SVO MkII
IL
It's actually 1.00, in the Ecoboost.
SVO MkII
IL
I do leave it in 5th quite a bit, but that puts it at 3500 at 80mph...and sometimes you need to touch 90+ (emergencies only!), which is 4000+. My preference is to try to keep the revs between 2-3K for regular driving. Just my preference. I do appreciate the excellent gas mileage that the 0.70 6th provides. I can get 32 mpg hwy, and that is with the 3.55s.
If you want to really experience "turbo lag", drive a '80s turbo.
justme97
justme97
Milford, CT
SVO MkII;2231721If you want to really experience "turbo lag" said:
It’s fine. It’s just that my 06 v6 explorer with full time 4wd and crazy weight seems to pull harder off the line than my eb is all. But it’s city mpg falls under 10 and acceleration goes away after that. I just have to get used to driving a turbo 4 again. I’m still breaking it in so I’m sure there’s a lot of boost fun ahead once I do.
ElAviator72
Canby, OR
Brent
TorqueMan
St. Jacob, IL
2017 EcoBoost Premium
So you would lose economy by never using 6th for street driving, which, as you noted, is the sole reason for the existence of 6th. What would you lose for competition driving if you never used 6th? Are you using your car for competitions requiring 140 mph top speed?
SVO MkII
IL
Again, it would be more comfortable to be able to put it into 6th and cruise around at 2500-3500.
I'm taking it Road America next weekend. In the 944 Turbo, I can get close to 130 before braking for turn 1. Not sure yet where I'll be with the Mustang. Looking at the gear chart for the EB PP 6spd, it would hit approx 138 mph in 5th at 6K (as you noted). However, I am interested to see if the car is still accelerating past 5K. Given the stock dyno chart, the motor appears to fall off rapidly above 5K. This may point towards short shifting at 5K as the best way to maximize speed. 5K in 5th is approx 117 mph. I'll have a better feel after next weekend as to how these ratios work on a long track.
Having said all that, I have no plans of changing the gears while I am still using this as my daily driver. However, the long term plan (as in 4-5 years from now) will be to turn this car into a dedicated track car. That is when I would seriously consider swapping out the "eco gear" for a useful, performance oriented ratio.
cocopanda
Bay Area
J
2019 Premium GT Coupe
I don't even have 2000km yet on mine, but this last tank I'm at 11.8l/100km (~20mpg) around half of that is city driving.
I could certainly do better if I tried ...
What's crazy. is I can pull this around town and highway driving with the 5.0. It's insane how much better on fuel this V8 is.
SVO MkII
IL
I should probably post an update, FWIW. I have grown to appreciate the factory gear selections on my car. It's basically a 5 spd with a highway cruising gear. On the track, I never use 6th gear. Shorter tracks can be handled with 4th gear, and longer ones (Road America) with 5th. On the highway, I can get over 30 mpg cruising in 6th. It's also worth noting that I have not experienced any diff overheating on track, as is common with the V8 cars. I'm guessing this is due to much less power flowing through the diff as well as a slightly taller ratio than the V8 PP cars (3.73). After 20 mos/28K miles, very happy with the car.
TorqueMan
St. Jacob, IL
Suspicion confirmed... :like:
FreePenguin
Ohio
Donald
17 mustang
Does a burnout ruin a clutch rear or a torsion rear or both are fine? I have done some burnouts with my 3.31 and I’ve never thought about mine not being the upgraded rear end
think it’s fine?
