20X10 wheels upfront
SK17
Michigan
Jason
Hello all. I want to get the FR500 deep dish wheels in 20x10/+43 offset/7.19 B.S on all 4 corners. I know they're fine on rear, will they be o.k up front. 2016 Mustang GT
Thanks!!!!!
compprep
Central, New York
Jim
19 GT PP1, 86 SVO, 24 S5, 74 MGB GT
A 10" and +42 will most likely require a spacer. Know you can't go much thicker than 5 or 6 mm as there will not be enough thread engagement. Then you require extended studs.
Prodigal
OKC
2021 Mach 1
I’ve got 20x10.5” up front but they are +24. I do have .5” extended studs and the tires poke a little. Once I install the PP fender trim they will look perfect and be flush with the trim. I think a 10” wide wheel would be easier and look perfect. I just wanted to get a 305/30 tire up front.
EFI
Masshole central
5.Br0
You'll need a spacer for sure. You might be able to get away with a 6mm one and stay on the stock studs, but it will be really close. It will also depend on what size tires you go with.
SK17
Michigan
Jason
Hey Guys. Thanks for the quick replies. I plan on putting the smallest tires up front that I can. I do a little bracket racing at the local drag strip. I just absolutely loved these wheels because of the deep dish aspect. I got tired of my previous ones. So even with smaller tires up front, you're thinking maybe 5mm spacers or not?
Jason
SK17
Michigan
Jason
I ordered 5mm Eibach spacers for the front. Do you guys think that I need to order the same spacers for the back so that the tires/rims match front to back?
J.D
