2022 non-HP to above HP conversion ALL STEEDA
Jimmy Dean
Baton Rouge
Al
TRDFurgesson
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
22 Mach1 N0426, 22 Bronco Wildtrak 2dr, 92 Yota 4x
Finally finished the LTH install despite my unheated garage... Flashed the 93 tune yesterday evening and it sounds very good... still quiet enough at idle even in track mode. Of course the audio is much better in person. Today I will install the Steeda Braided brake lines.
TRDFurgesson
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
Note: If you swap out your Magnaride controller with a different controller like one offered from Steeda, I have a note for your install. When you remove your subwoofer (if installed) be careful with the clip nut at the rear top of the frame that supports the subwoofer. If you knock that clip nut off you'll need a telescoping magnet to get it out if you're lucky. JUST DONT KNOCK IT OFF and into the space between the trunk and bumper. Also there didn't seem to be much room between the harness and the vent located in the right rear fender.
RandomTask
DFW
Aaron
2021 Mach 1, 2020 F350 DRW Platinum
what gains Are you expecting from the LTH and 93 tune? Other than noise.
TRDFurgesson
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
Noise is in the ear of the beholder... I'm guessing 30-40hp with the 93 tune. I only run the car in summer so E85 is the fuel of choice. I am expecting to see 70-90hp gains on the dyno with E85(500 +-15hp to the rollers) Ill switch back to the 93 tune before I put her away for the winter(temps consistently below 40F). If I get a chance to put her on the dyno before putting her away for the winter, I will. Right now 93 is at about $4 per gallon, E85 is $1.85 per gallon.
TRDFurgesson
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
The first clip was the last open test and tune from last year. The second and the third clip are from the first open test and tune May 4th this year.
RTR077
Denver, NC
James
2021 Mustang GT RTR Spec 1
Great videos! Keep em coming
