2020 GT Premium HVAC Control issues
ConnMusty
Connor
2020 Mustang GT Premium PP1
I have a 2020 GT Premium and am having a few weird issues with HVAC controls, and am curious if anyone has come across something similar, or have a potential solution(s) to this problem.
On my car, the HVAC controls are disobedient at best. One issue I have is the absolute inability to turn off A/C other than completely turning off the HVAC system entirely (no blowers at all). Another is the inability to turn off the defrost setting, even when it is not selected on the SYNC screen. Sometimes the front blowers do not function, but I can get lucky by changing a few blower settings, in which I have found that by running the defroster and the front vents, I can finally (but sporadically) run the front vents. If I select only the front vents, my defroster still blows despite it not being selected. Auto A/C sounds like it cycles vent motors, then may default to defroster only.
The blowers don’t make any strange sounds. To me this issue appears to be a confusion on the communication between the buttons I press for my desired vents, and what the HVAC system actually does.
Is this a fuse problem? Is there a HVAC positioning relearning procedure?
Any suggestions are much appreciated
ConnMusty
ConnMusty
Connor
Hard to say what the issue really is, but one of the most common issues with the HVAC system is the blend door actuators. Not sure if this is your issue or not, but it’s something to check out,
Check this thread RE: blend actuators
https://www.mustang6g.com/forums/threads/good-old-hvac-actuators.209605/
That seems like a cheap/relatively easy item to check and replace. I can definitely start there. On the same subject - Any recommendations for an OBD-II reader for FORSCAN?
