2019 PP1 brake pads
JJJ
2019 Mustang GT
Question, are the rear PP pads the same pad material as front PP pads or same pad/stock number used on regular GTs?
Lastly, in looking at my 19, the rear pads have a spring that separates the pads from the rotor, does the 18 as well?
I was looking at Power Stop Z23 pads due to he dusting of track pads.
Thanks.
sdiver68
St. Louis
18 GT PP1 10R80 Vert
I like my Powerstop Z23 for daily street use. After the bedding and first week or so they really are almost dustless. Id say stopping effort increases a bit from the stock PP1 dust devils.
I dont remember a spring on my 18 PP1.
JJJ
JJJ
2019 Mustang GT
Thank you!
Chef jpd
Brooklyn, NY
I think the spring you are seeing on the rear is part of the emergency brake assembly.
JJJ
JJJ
2019 Mustang GT
No, it's a wire spring that connects the outside pad to the inside pad (over the rotor) that pushes the pads off the rotor when not engaged. Perhaps for cooling? The new Z pads didn't have the springs so the pads are just placed in to the caliper.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
More likely for friction reduction (think mpg here).
Norm
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I'm putting 6 piston brakes on my 2015 GT. I haven't purchased the rotors and pads yet. The car will be mostly street driven. Any suggestions? The stock pads at a sale price are $200. Anything aftermarket as good that are a bit cheaper?
jacknifetoaswan
Charleston, SC
As someone else suggested, the Power Stop Z23s. I've been running them for two years, and they're great. They reduce the initial bite of the stock PP pads, though stopping power seems just as good. The reduced initial bite allows a little more pedal travel, which gives better heel/toe and allows for increased modulation of the brakes. They're also very low dusting.
JR
GreenS550
Bob
OK so I'm looking at the z23 package from Rock Auto. Includes the Z23 pads and drilled/slotted rotors. Are these rotors any good or should I stick with stock solid type of rotors?
jacknifetoaswan
Charleston, SC
I don't like taking the risk of cheap drilled or slotted rotors. The OEM rotors are really solid and getting cheap aftermarket drilled/slotted rotors isn't going to be an upgrade. For one, cheap rotors don't always have good casting or machining, the rotors can crack under heat and stress from the drilling and slotting, and the slotting is constantly wiping the pad - good for racing (keeps build-up off the pad surface), bad for longevity of the pads.
JR
GreenS550
Bob
JR
That's what i have experienced in the past. That was a long time ago. Makes sense. The standard rotor is what I'm leaning to. Thanks.
Norm Peterson
Norm
'08 GT #85, '19 WRX
Drilled isn't worth the money for street duty or the risk during track driving.
Slotted does at least give little bits of dust and grit a place to get wiped off into (instead of becoming embedded in the pads and scoring the rotors), which is at least a useful appearance factor. Pad wear may not be all that much faster than with plain rotors - I've used both plain and slotted/grooved rotors in both track and street driving.
Norm
sdiver68
St. Louis
I have stock pads with 500 miles that id sell for 1/2 price since Ill likely never track this car. I always switch to low dust ceramic for the street ASAP.
