turnswrench
turnswrench
Found some good pump e85 to tool around with:
Thank you. It all means nothing if I can't pilot this bucket into the 8's this season. The snow is falling in MN again, oy vey.Same E85 tester I have lol.
Congrats TW, you really took that car to the next level in last 3-4 months.
So you just wired them into the output of the fuel controller? Seems simple enough and a wise precaution. Thank you!https://www.mustang6g.com/forums/threads/solarflare’s-better-late-than-never-build-thread.104447/page-6
first post. These are more in case I burn a fuse in the FC3 (which is not uncommon) but would work for you, as soon as you get the trigger for your 2nd or 3rd pump these lights would theoretically come on for you, while pump #1 would always be on.
Great advice. I think I'll write a jig to do that safely to try starting the car on each pump individually now and then. Thoughts?While the LEDs are a good indicator of output to the pump, it does not give any indication to other fuel related issues. Weak pump, clogged filter, pressure dropping off or dead pump. Manually test multi pump setups frequently.
It accepts zeitronix, which accepts fuel pressure/etc. I like the idea of playing with an adjustable fuel pressure switch to do something.Does the ngauge accept a fuel pressure analog input to the back of it??
no, and yes. The analog inputs are 5v. So need zeitronix, or boost box omega for fuel sensor input. or exact resistors added to the 12 v circuit and custom correction factor, and correction offset.Does the ngauge accept a fuel pressure analog input to the back of it??
