texansin83
Has anyone upgraded the non PP belly pan to the Performance Pack one? If so do you need to buy all the hardware or can you use the same hardware that is used with the Non PP one.
I upgraded to the PP belly pan due to upgrading my chin spoiler. You can reuse your hardware, but you will need some extra screws and push-pins.Has anyone upgraded the non PP belly pan to the Performance Pack one? If so do you need to buy all the hardware or can you use the same hardware that is used with the Non PP one.
Where did you get your PP belly pan? Any tricks when installing it? I am looking at doing the same thing to upgrade my chin spoiler as well.I upgraded to the PP belly pan due to upgrading my chin spoiler. You can reuse your hardware, but you will need some extra screws and push-pins.
Tasco Ford parts online. The PP version installs the same way as the non-PP pan, just a few more fasteners is all. I also cut my fender liiners where the brake cooling channels in the pan mated up for the airflow. Just use a razor knife and a steady hand.Where did you get your PP belly pan? Any tricks when installing it? I am looking at doing the same thing to upgrade my chin spoiler as well.
hey, looking at doing this as well. do i need to cut the liners or is not 100% necessary? thanksTasco Ford parts online. The PP version installs the same way as the non-PP pan, just a few more fasteners is all. I also cut my fender liiners where the brake cooling channels in the pan mated up for the airflow. Just use a razor knife and a steady hand.
Not required unless you want to uncover the inset airway for the PP scoop on the control arm that diverts air to the brakes.hey, looking at doing this as well. do i need to cut the liners or is not 100% necessary? thanks
