DickR
I don't autocross over cliffs or even steep downhills. Therefore the car won't accelerate to a higher rpm/mph without engine power.Momentum. Put the car in fifth and roll it down a steep hill with no throttle and you'll log 9500rpm. Redline is still 7400rpm.
Anyway for anyone who might care
What actually happened in my previous 2012, 2015, and current 2018 GT's based on "on the rev limiter data" is that the PCM rev limiter reduces throttle percentage until the rpm drops "slightly" and then adds throttle as needed to "hold" rpm at/near the "rev limit" until the stupid driver finally lifts.
In the run where OBD data shows 7530 rpm max rev limiter action started at 7510 rpm when the throttle dropped from 100 percent down to about 30 percent and rpm dropped to about 7250 in about 0.2 seconds after the rpm reached 7510. Then it went up to 7530 in about another 0.2 seconds. Then it dropped to and stayed close to 7500 for another 0.3 seconds before I lifted. Longitudinal acceleration dropped to nominally zero within about 0.1 second from when the PCM rev limiter initially started reducing the throttle percentage at 7510 rpm and then stayed there until I lifted.
Note that with my 2015 GTPP (manual of course) rev limiting in second gear usually started between 6800 and 6900 rpm. I'm not sure it ever hit the "advertised" 7000 rpm "redline" but it did get into the mid 6900's sometimes.
