Thats a shift point. Not an engine limit.lol. Regardless......it’s not 7500, it’s 7400.
There’s a 7400rpm limit on the transmission
What assumptions? he posted data pulled from the oem tune. It clearly shows a limiter at 7500.It’s not a shift point....and there are a lot of assumptions being made about the data Nuked posted. Read the whole thread, mate.
Why so angry bro?
See below.What assumptions? he posted data pulled from the oem tune. It clearly shows a limiter at 7500....
Cheers Team Nuked, thanks for clarifying....As for the other screenshot, I can assure you that you will hit the Temp based cutoff before you hit the rev limit cutoff atleast while accelerating (not neutral). I learned this tuning my 16 and kept hitting a wall at 6850 even though I changed the rev limit to 8000. Once I changed the temp based to 8000 problem solved. Below is a 16 stock tune from my car. Notice that the difference between the rev limit and temp based is 150rpm, just like the 18. Stock 2018 is 7350, stock 15-17 is 6850 so yes Ford did raise it 500rpm.
If you hold it in gear, it smacks right into a rev limiter. I've done it a few times.That is the WOT shift points. I am not an auto guy, so not sure what the modes refer to. I would assume the different "modes" shown to the right, but I only see 17 not 19 as the chart references. I don't believe there is a "transmission rev limit", as you can see at WOT the shift point is pretty close to the rev limit as is. What happens if you manually use the paddles to hold a gear, does it hit a limiter?
The difference being a hard limiter, 7500, and a situational limiter of 7350 based on temps.See below.
So, back to the question of whether the redline is 7400 or 7500rpm? You found the "hard" limit is 7350rpm. I suggest Ford selected a 7400rpm "redline" (clearly defined on the digital dash), and not 7350rpm as the increments on that display are in 100rpm steps. Hivel found his ECU had a Transmission Protection limit of 7400rpm so it gels that the redline is 7400.
That would be an interesting experiment, especially with rev matching... I don't plan on testing it with my Bullitt, but any other brave souls out there, for the good of the community........down shift a manual, see what happens.
And again, the manuals don't have said protection.
