roblilly33
- Jun 3, 2019
- Austin, TX
- Rob
- 2018 GT A10 Whipple Stage 2
On teardown I was told:
Hey Everyone,
I have the disassembly finished up on the block and have attached pictures of what I found.
The ultimate demise of the engine was the cracked cylinder. The cylinder eventually hydro-locked bending the rod. From the pictures you can see the engine "tune" looks ok. None of the pistons had speckling or signs of a lean condition. The head gaskets don't show any signs of failure either eliminating overheating or extreme lean condition under boost.
All parts installed check out as well, no signs of a boost leak or a fuel issue. I have an email out to a couple engine builders that are very familiar with coyote engines to try to find out more information on this failure.
It looks like the piston was either scuffing the cylinder wall or the liner started to fail, causing the piston to put uneven pressure in the cylinder bore. With the uneven pressure and possible boost on top of everything the cylinder wall eventually failed. I want to point out that the crack is also at the weakest point in the block deck. All other head bolt holes or coolant jackets are supported to the outside of the block. The largest unsupported area is on the top, between the two cylinders and the head bolt hole.
My thoughts our this really comes down to a "design flaw" and not necessarily anyone's fault.
Hey Everyone,
