Doesn’t the 5.0 operate in PFI only mode at idle and low load? If so, why would there be a DI tick at idle?@mvjet you mean the DI tick sound in idle or the low rpm rattle sound theory related to DI and sound toube ?
It is unlikely the actuation is completely shut off at idle. I work in fuel system development. In the ECU logic, we don't shut off main injection events at any point. We may use an energizing time low enough that the volume injected is basically 0. You will still hear actuation of the solenoid or piezo.Doesn’t the 5.0 operate in PFI only mode at idle and low load? If so, why would there be a DI tick at idle?
How does it "appear to have been a lie"you're the idiot that decided to pm me uninvited with an I told you so message that appears to have been a lie.. if you notice I have quoted some of your posts in this thread so they last forever. i'm sure you're aware that Ford does look in places like this when they suspect a car with a warranty claim is not stock as claimed. ohh and it doesn't matter if the Tune was only on for 30 seconds or 30 days, the fact that it was tuned period is the issue with Ford.
Yup but unfortunately some of us have it worse than others. Upon inspection there is slight damage inside the engine.For everyones information....
SSM 46173
"Some 2016-2017 Mustang GT350 equipped with the 5.2L engine may exhibit a rattle or rapping type sound during cold operation at light loads and speeds from Idle - 3000 RPM. The noise will be most noticeable during light acceleration in the 1500-3000 RPM range and may also be noticeable in the 800-1200 RPM range with neutral throttle blips. This sound is caused by the piston motion in the cylinder bore. This is an inherent characteristic of the forged aluminum pistons utilized in this high performance engine. Once the engine reaches operating temperature the noise will diminish, although it may still be noticeable even when fully warm. There are no durability concerns with this sound."
Yes our engines likely do not have forged pistons but the 350 engine is the closest analog to our engine out there. The issue described in this service bulletin matches perfectly with my sound and others. Even with forged pistons which I would expect the issue to be worse on, Ford states no longterm durablity concerns.
once I have been to the dealer I'll keep you updated. I also guess it is normal.For everyones information....
SSM 46173
If you can, post pictures of this damage. Also keep in mind that the rattle doesn't seem to occur until a few hundred miles. (likely when the anti friction coating on the piston starts to wear. That coating doesn't last long)Yup but unfortunately some of us have it worse than others. Upon inspection there is slight damage inside the engine.
To each his own. I dont appreicate the rattle at all. Especially when I test drive other stangs in Atlanta and not one made the noise.
My car sounds just like yours and I'm thinking it is normal and related to the DI since it is different from an engine knock. Thanks for your videos - makes me feel better. I will report it as well to my dealer when I next take it in.once I have been to the dealer I'll keep you updated. I also guess it is normal.
Mine was doing it at 30 miles. Ill try to get photos of the damage.If you can, post pictures of this damage. Also keep in mind that the rattle doesn't seem to occur until a few hundred miles. (likely when the anti friction coating on the piston starts to wear. That coating doesn't last long)
I see you are getting a new shortblock like some others - did you just have the dealer use the bore scope? Was it straight forward? I thought I read earlier that you had to go to a second dealer - but perhaps that was someone else.Mine was doing it at 30 miles. Ill try to get photos of the damage.
First dealer said it was normal.I see you are getting a new shortblock like some others - did you just have the dealer use the bore scope? Was it straight forward? I thought I read earlier that you had to go to a second dealer - but perhaps that was someone else.
Thanks,
Yes this is what I posted in my first post. We do not have forged pistons and this came out after a Year or two passed so Ford had time to look into the issue and make that conclusion. I think our problem is a casting issue or deformity since the scoring is in odd places.For everyones information....
SSM 46173
