2017 S550 3.7L V6 A/C Troubleshooting
BamaLandYacht
Alabama
Alex
2017 S550 3.7L
New to the site, joined for hopes of insight on our 2017 S550 A/C issues before I take it to a service shop or the dealer.
I’m fairly well mechanically inclined and have performed the following testing as follows
7.5A fuse in passenger kick for interior cliamte controls verified
10A fuse in position 23 for ac compressor verified
A/C relay verified by swapping for horn relay
A/C compressor Clutch manually powered by bypassing relay with engine off to verify working clutch engagement on compressor
I'm in the process of either buying, renting, or using a lent pair of decent ac gauges this weekend to verify pressure
The condenser fans run constantly non stop since the issue originally started.
in my eyes I’ve narrowed it down to low refrigerant, bad pressure switch or… god forbid a expansion valve witch if is the case I’ll probably sell it lol.
If anyone has anything I might of missed or any suggestions I’m all for positive or negative feedback!
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
If the evaporator was never replaced, I vote leaky evaporator. Mine had the same symptoms.
BamaLandYacht
Alabama
Alex
2017 S550 3.7L
I know about 5 years ago the A/C condenser radiator was replaced at the dealership for tanking a brick piece on the interstate
MrMike
US
BamaLandYacht
Alabama
Alex
2017 S550 3.7L
MrMike
US
Yeah I was aware, just wanted to state that the condenser radiator had been the only thing ever replaced on the a/c system.
I’m hoping that I can get my hands on a set of gauges in a day or two and I’ll give a update!
Gotcha, good luck man. It's the only problem I've ever had with the car. It's been good since the new evap thankfully.
ORRadtech
Atlanta, Georgia
Harbor Freight sell a decent set for like $65 if you're into owning your own tools. I don't use mine all that often but they're invaluable when I need them.
