2017 Mustang GT ticks
bl4d3runn3r
Chicago
Blu Fury
Hi guys,
my 2017 Mustang GT base model ticks since a couple of month when it is not warmed up. I googled a little bit and found some others with the exact same noise.
I can hear it very well in my garage in the morning and it doesn't sound very healthy.
Here is a video of somebody elses car having the exact same noise.
It is quite hard to replicate if no gear is in, but in 1 and 2 gear I can hear it a lot.
After the car warms up the noise disappears. Was at the dealer, but I couldn't replicate it. Does anybody know what the issue is?
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
Hi guys,
My car does this a bit when cold with that BBQ tick. I've heard it in parking garages and when leaving my house when the windows are down. I looked into it and chose to just ignore it. Seems like a lot of the Coyotes do this. I don't see any check engine lights or anything that appears to feel wrong with it. I chose to just let it go since its gone when everything is up to temp anyway.
Think it has something to do with the bearings and lubrication.
bl4d3runn3r
Chicago
Blu Fury
OK, then I will live with it. Luckily I can't hear it on the inside of the car.
Zelek
2021 Mustang Mach 1
If anything, as anyone should regardless of car, don't drive it hard until things are up to temperature.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
I get this at 1750-2000 RPM especially when warm...
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
That sounds so weird and it sounds like the rpm would drop when it happens. It almost sounds like a bad pinging.
usgiorgi
Fairfax, va
C6 Z06
A member on here had this noise, sent oil to blackstone labs for analysis. They said it all looked great. Then he took it to the dealer and they found that there was engine damage. That noise is absolutely not normal for a healthy car. It's ridiculous that anyone thinks it's ok. Don't bury your heads in sand and pretend it doesn't exist. The source needs to be found in each car before the warranty runs out and you're left with a 600lb paperweight of an engine.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
I was at the dealer last week and hope to get it opened up this coming week. They said they smelled burned oil and just changed the oil 2-2.5k miles ago. My ticking is only heard when warm now but is consistent. I got videos i will post them when i get off my flight later tonight
MasterCylinder
Fort Worth, Tx
(sold)17 GT
soldier989
Columbus OH
2017 GTPP Premium
Eww, I'd be sure to take that in. It changes as you rev and is never consistent. It doesn't sound right, and even if its the BBQ tick, get it documented at a dealer.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Finally dropped it off. Thankfully I got the extended warranty so no out of pocket for a rental/loaner... Which was not brought up prior. Updates when I get them.
usgiorgi
Fairfax, va
C6 Z06
It's so weird that Ford doesn't automatically give you a loaner when your car which has a warranty is in the shop for a problem... It's ridiculous.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Agreed. I was told there has to be more than 4 hours work hours scheduled before they will cover a rental.... Until then it is on my dime. But if they are backed up and won't get to it for a couple days and you can't bring it in when they are ready you're kinda SOL.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Was called yesterday... Apparently my concerns and replicated ticking coming from the engine were not translated to the mechanics properly. I am some how getting a new throw out bearing instead. :doh:
