2016 Roush mustang malfunction HELP!
speedgod
canada
s550 mustang gt
Hello Guys!
I got a 2016 Mustang with a Roush Phase 2 supercharger on it. Recently I installed LTH on the car, a custom-built mid-pipe, and a secondary 02 bung installed on the mid-pipe. Everything was running smoothly no check engine light nothing. Everything changed 3 days ago, one of my secondary 02 shot out of the pipe due to the lack of penetration on the weld. The 02 sensors were busted and the check engine light came on after I started the car back up. I unplugged the 02 that was dangling and started to drive home. I didn't think much of the check engine light because it must be one of the secondary 02 being unplugged. I also notice that the AFR was stuck at 14.0 no matter the speed or the rpm. I took the car back to the exhaust shop the next day they fixed the weld and installed a brand new 02 sensor for me with new dummy plugs. But the check engine light didn't go away and there was a lot more code than just emission codes I got the shop the delete the code for me but the codes came back and my AFR is still stuck at 14.0. I'll list the codes below. I have no idea what's going on and what the next step will be, if anyone could give me some expertise and pointers that would be much appreciated.
Thanks, guys!!!
P0443Evaporative emission system purge control valve circuit
P0013Exhaust camshaft position actuator circuit
P0020Intake camshaft position actuator circuit
P013502 heater circuit
P014102 heater circuit
P015502 Heater circuit
P016102 Heater circuit
p0446 Evaporative emission system vent control circuit
P0010 Intake camshaft position actuator circuit
P0023Exhaust camshaft position actuator circuit
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
Pinched or ruined wire somewhere? Usually with my cars, lots of codes at once has been something like that
Have you checked out your wiring harness really well? How bad was it when the o2 sensor shot out and was dangling? Try a KAM reset for fun
