its still gonna weigh about 3700 lbs. depending on which option you get.
What I'm saying is if the Caddy can come in light weight, why can't a base Camaro that's on the same platform. Realistically, GM isn't going to add more NVH, wheels, tech and safety stuff than a Cadillac ATS.No, just as the C7 lost 99lbs in the structure and suspension, it gained 210lbs overall. Again, the Z51 package added 150lbs too.
Right now, the rolling chassis has lost 200lbs. Now the content is added...
Brakes, wheels, tires, exhaust, NVH, engine (50lbs by itself), transmission, interior and safety is the issue now.
I will post the C7's weight gain list so you can understand where the weight is coming from.
The ATS-V is already over 3700lbs. The Camaro will struggle to beat that with an LT1.What I'm saying is if the Caddy can come in light weight, why can't a base Camaro that's on the same platform. Realistically, GM isn't going to add more NVH, wheels, tech and safety stuff than a Cadillac ATS.
I see 3,700lbs as the weight.The ATS-V is already over 3700lbs. The Camaro will struggle to beat that with an LT1.
Also, I'm sure the Camaro is wider and has more track than an ATS.
Just adding the LT1 and Tremec to the LS3 and TR6060 weight is 70lbs easy. The key now is to eliminate content weight and shoot for a sub 3800lbs car. The Camaro could use ATS-V size brakes standard, that is a pretty decent gain in that respect.
The NVH material will likely be more than previous Gens, about the same as the ATS.
The Corvette gained 210lbs in content after its victorious 99lbs reduction. Looking at the list, I can see close to 200lbs coming back on after the 200lbs reduction.
Al O. Says a lot... very little translates to real world. It's possible they slashed everything just to weigh less. The Camaro could weigh 3900lbs even and still be a weight loss. Rotating mass, unsprung and sprung is probably less, that's a good thing.I know it's PR speak, but would Oppenheiser really say the Camaro's handling and braking improved (attributing it to weight) if there wasn't a net positive weight loss?
