2015 mustang cranks no start
Mudhar17
2015 mustang gt
Hey guys so I was just chilling loading up a new tune loaded just fine then I tried to crank the car to start it and it doesn’t start just cranks checked fuel pressure regulator and it’s reading 0 fuel pressure. The car is 2.9 whipple with vmp fuel system installed by a shop and was running fine until right now. I went ahead and checked fuses by the fuse box and the one inside the fuse box and they all seem good and not blown. I don’t hear the pumps priming when I took off my back seats. Could it be that the fuel pump died? I just installed it like less than a month ago and only driven the car for like less than 800 miles maybe even less.
R34P3R
Seattle, Wa
2021 GT Premium
Old tune it started, new tune it doesn’t? Can you reload the old tune first to see if it starts again?
whizkidder
Georgia
Ron
2017 GT Premium Convertible
Do you have remote start? Might try that. Had a similar issue (but no tune), no prime with foot in brake, but car would start with remote. Re-seated all the fuses and wire harness connectors on the BCM, and the issue went away.
Mudhar17
Mudhar17
2015 mustang gt
Ya bro I tried this I even reloaded stock tune then retuned it tried all 3 files I have
Mudhar17
Mudhar17
2015 mustang gt
Tried it no luck
wingnutt
@FL410
michael
350R Procharged w/P1X
Call your tuner…there’s lots of options for them to check, or un-check 😉
Angrey
Coral Gables
2016 GT350
If you've reloaded previous tunes that didn't have the issue and it still persists then that's decent evidence that it's mechanical. May have been caused by the new tune, but I'd check the fuses, relays and the FPDM (if you're still using it). I'd multimeter and check that it's giving signal to the FPDM for initial prime (which should momentarily on-off when you press either brake or clutch or start button). Then check between the FPDM and the relays. Then check in between the relays and the pumps.
Mudhar17
Mudhar17
2015 mustang gt
Do you know where the relays would be on the vmp fuel system
