2015 GT PP oil question
skibbles
2015 Mustang GT PP
Hey guys! New around here currently driving a 2015 GT.
My question for you all is whenever the temps get above 100 here (Austin) I will every now and again get a low oil pressure light on the center screen at idle (track only). As soon as i rev the motor or begin driving it goes away so the light has never stayed on for more than a second. Currently running Motorcraft 5w20 like I was told to do but I think I want to step up the oil weight a bit.. any suggestions? thanks in advance fellas
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
I assume you checked the oil level and it is ok? I never had those issues in the warm Atlanta weather when I was running 5w-20.
dfrost
Florida, Jacksonville
2015 mustang gt pp Guard.
Please check your oil level asap. What's your oil pressure gauge reading?
If your oil level is OK, take to dealer asap!
Oil weight is not causing this. Nor is temp. You have either a faultly sending unit or enterenal engine problem. Get it checked!
skibbles
2015 Mustang GT PP
yes oil level is fine thank you for input pretty positive it's heat got a few tips for this weekend
EDIT: just read spec for these cars is 10-15 warm idle it goes to like 9 at its worst... sorry to waste your time fellas
Todd15Fastback
Atlanta, GA
Todd
9 seems awfully low IMO. When I ran 5w-20 I was at 20-21. Now that I run 0W-40, I am at 30.
dfrost
It's not heat.
These motors are designed to run 5/20.
I'm in FL, 100*F, run 5/20 and warm at idle 20-25 psi.
skibbles
2015 Mustang GT PP
got ya well then i guess mine has been broken for 20k miles lol
and only at the track..
Asharus
Boca Raton, FL
Angelo
2018 Challenger Scat Pack
are you the guy on facebook that posted videos from inside the car drifting? i posted a comment in there saying that oil pressure seems a bit low.
the lowest ive seen mine at idle is 20 psi. i remember in the video you were at 40 psi at redline.
edit: video for reference
[ame]
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Any engine should generally have at least 20 PSI at idle hot, or 10 PSI per 1000 RPM.
Anything less is going to be a problem.....
Asharus
Boca Raton, FL
Angelo
yeah from his video the highest his oil pressure seems to go is 45psi, even at redline
Wblv17
older fart
Crazyville Texas
Rob
2014 5.7HEMI Ram and 2015 eco boost race red pp
26 is the lowest ive seen, normally at 29 at idle
