BlackandBlue
One solution might be to install a check valve right before the catch can.
Then run a hose the size of the pcv inlet in the head to a bigger hose about 3” tall, reduce in size, 90 to the hose running to the separator. Run the hose up hill as much as possible.
This would allow the oil to run back into the engine under wide open throttle. With a pcv once it gets past the pcv it’s stuck until it collects enough to burb a slug into the catch can or engine.
One other idea would be to put and extension on the end of the PCV so it doesn’t stick down as far in the valve cover.
