2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion
john@fatfab
Indianapolis
Shelby Omni
It is a mechanical pump in the trans.
Also.. I got my factory dif pump working just fine with the pin out and an ohm meter. I bought the short pigtail for the plug that goes into it and will be splicing it into my stand alone, switch operated setup.
What pins did you apply power and ground to?
zombiekiller
warranties are 4 wussies
New Orleans
16 gt350, 66 galaxie,a Tesla, and an AMG G63
pin 6 is ground.
I have 1 & 4 jumped to switched power right now with a single pole relay and a switch.
I havent had the time yet to monkey with test wiring a multiple manual switch control to have more than 1 speed.
I'm betting that I'd actually have to use a variable voltage set up to alter speed. I just need to dig into further.
pin 2 is my constant fused power.
I'm not sure what the "diagnostic" pin actually does. I'm not terribly invested in making it function as it does with a factory harness.
As of now, I've test wired it to validate function.
Finishing testing and doing a nice, clean, wiring job with weatherpack connectors isnt going to happen for a few more weeks.
Here's the pinout:
Hack
Minneapolis
Mustang, Challenger
Hey [MENTION=12069]Hack[/MENTION],
You make a compelling argument for the tranny swap...I keep going back and forth with always falling back on a couple points: 1) my existing transmission is stock to the car and will perform as advertised with the cooler & 2) I really don't want to fork over more $$ to Ford..
Could you offer up some of the factors for you in deciding on the full tranny swap?
Thanks in advance :cheers:
I really haven't decided whether to do a transmission swap or not either. In that post I was just trying to give my thoughts regarding the difficulty of installation of the different options. I have done a fair amount of wrenching and have more balls than brains sometimes when it comes to going ahead and doing something myself. Most of what I've done for wrenching hasn't been on such a new and expensive vehicle, though.
I don't want to do the transmission swap because as far as I know the pump is running all the time, and I would prefer to only have the pump run when it's actually needed. I think the track pack transmission will run too cold in the winter. The additional cost is a factor as well.
I don't want to do the electric pump because I'm not very comfortable with whether the fluid levels will be correct when the pump isn't running and I really don't prefer to have the pump run all the time.
Right now I'm leaning towards replacing the transmission despite the fact that $3,000 or $4,000 is a significant amount of money to me. Since it's a proven, factory designed system I think it will be very reliable and I won't have to worry about it or inspect it frequently.
juice ain't worth the squeeze.
Dave Kindig - Bitchin' Rides. :)
I remember hearing him say that on the show and thought it was pretty good. :thumbsup:
zombiekiller
New Orleans
its actually an old southern saying and fairly common.
The only thing i know of kindigit is that once upon a time they made some cool door handles for hot rods. :shrug:
Minn19
Minnesota
Jason
19 ZL1 1LE, 19 F150, 19 SB S5
Why do people do this? They do good work. Give this crap a rest.
zombiekiller
New Orleans
i literally have no concept of what kindigit does beyond door handles for hotrods.
I'm not clear on why you find that so offensive.:doh:
Minn19
Minnesota
Jason
Sorry, I thought it was the usual other people crapping on other people's work because they are on tv etc. I misread the meaning of your post, sorry.
Hack
Minneapolis
Mustang, Challenger
Huh, interesting. The episode where he said it aired within the last week or two. That's why it was fresh in my mind. I had never heard it before.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
He builds some pretty bad ass rides, some of which i'd like to own.
lemers
Globetrotter
Carlisle, PA
2016 GT350
I'm with you on going back and forth, I think I'm going to use a "step up" strategy. I will start with an external pump ; knowing that eventually I may need to replace the transfer with the internal pump.
zombiekiller
New Orleans
he gets a pass. He built a pretty bad ass 65 galaxie and managed to get over 250K for it.
( yes, i had to look him up :))
his shop also did a better job installing kindigit door handles than i did. :headbonk:
1Voodoo
Boynton Beach, FL
Adam
2016 GT 350
Can we get this thread made into a sticky??? does anyone have any updates on this process? I have a shop putting together an estimate and would love to hear how its worked out for other, parts used and cost.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
I'm interested in hearing when SA will have their cooler kit out.
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
Ill have the factory diff pump and mount for sale at a good savings over new...never used..just mounted..
