TexasRebel
Gearshifter
- Mar 19, 2016
- between the mustard and the mayo
- 2016 YZ GTPP - PP2
Get closer to the pedals and put your heel on the ground!- 1st gear between stop lights in city traffic, if you let off the gas, the car jerks like a son of a bitch and since your foot is right by the gas pedal your foot taps it just enough to cause it to give gas again and so all of a sudden you end up in this unexpected, violent jerking cycle. Absolutely unacceptable.
This is what my little sister did when trying to learn to drive stick in a 2002 Siverado 1500 V6.
This stops when the system warms up.- Often and unpredictable, it takes about a second or two after I lift off of the gas (clutch pedal all the way up...) for it to go into engine braking. So long, in fact, I CAN HIT THE BREAK AND IT WILL STILL BE HOLDING REVS! Another absolutely unacceptable trait.
You aren't really supposed to drive with a cold engine. Wear is increased. Have you ever noticed how aircraft warm and load-test their engines before takeoff? A failure there doesn't just leave you stranded.- When the engine is not at full operating temp, but still okay to drive, it rev hangs between gears which is blatantly unnecessary and only harms the clutch. It makes you shift like it's your first time. Once you change gears it does not stop holding the revs until you pass that point with your own pedal operation. WHAT THE HELL?
That's the good part about the tunes and providing the ProCal tool with the kit. The tune can be tweaked in the future. If it will is yet to be seen...I will be calling Ford Performance to discuss this throttle mapping with them. It happens in regular mode, sport mode, track model, and winter mode. It's insane!
I would be a fan of less rev-hang and a way to turn NLS off, but those definitely aren't too much of a nuisance.
