2013-14 Coyote Head Bolt Torque
Ueberhopft
Germany
Lucas
1967 Mustang Coupe I6, 2013 Mustang GT/CS
Hi Forum,
Which is the required torque for the 2013-14 Coyote Head Bolts with the 11mm Bolts. I have only been able to find information about the earlier 12mm Bolts.
Thanks in advance
Ueberhopft
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Ford Mustang Cylinder Head Torque Specs : 18 ft-lbs + 30 ft-lbs + 90° + 90°
Ueberhopft
Germany
Lucas
Hi Cory,
Where do you have this information from? Are you sure that that's the correct torque for the M11 Head Bolts. I am sorry that I am so OCD, but I come from germany so you can imagine how expensive it gets when something breaks.
Thanks in advance
Ueberhopft
BlackandBlue
Mustang
I don’t know but you can search or purchase a factory service manual for you vehicle.
If you are OCD, having step by step directions along with every torque spec will be something you will greatly value.
Do your due diligence before downloading from random websites.
Ueberhopft
Germany
Lucas
Hi Black and Blue,
Thank you for your suggestion. I already have the service manual but I am pretty sure that it is for the 2012 Mustang Gt with the 12mm Head Bolts, not for the 2013-14 Mustang Gt with the 11mm Head Bolts.
Could please anyone else verify the torque values stated above for the 11mm Head Bolts.
Thanks in advance
Ueberhopft
Cory S
Bradford, NH
Cory
wazslow
PA
2016 Mustang GT/CS
Hi Black and Blue,
Thanks in advance
Ueberhopft
11-14 are Gen 1 Coyotes, aren't they all the same? I thought they changed with Gen 2(15-17) and again with Gen 3(18-present).
wazslow
PA
2016 Mustang GT/CS
11-12 are 12mm and long
13-17 are 11mm and short
18-23 went back to the same spec as 11-12
Good info, thank you!
Ueberhopft
Germany
Lucas
I am thanking all of you for your replies.
I just called FRPP and asked them about the Torque values for the 11mm Head Bolts for the 2013/14 Gen1 Coyote Block.
1. 25Nm/18 lbft
2. 40Nm/30 lbft
3. 90°
4.90°
Hope you all have a great day.
Ueberhopft
