WhyNot
- Sep 30, 2016
- somewhere in Merica
- 16 Mustang V6 6-speed
yup you got it
looks similar to the one I have, except mine is grey. 5/8 ID clamp, so yeah that'll workThose who have added the driver side breather - I've read its a 5/8 ID clamp on style breather needed. I just want to confirm that the one in the link is correct. I keep forgetting that I have JEGS around me.
www.jegs.com/i/Vibrant-Performance/231/2166/10002/-1
Ahhh didn't even think about the tires That throws everything off...the stocks were 235/50r18 and the ones I did the second test on were 225/45r18out of curiosity, were these runs made in the same location, and in similar weather?
and the biggest question, is the diameter of the tires the same? because if your running smaller than stock diameter tires, it throws off the readings...
what size tires were used on both tests?
Looks like you have a bit to much torque on the TB side and not enough on the intake side. I would loosen up the TB bolts and tighten the intake bolts some more (if possible). While that will still seal, it shouldn't be flexing that much.So I got it all wrapped up, took it for a spin around the block (cant do much more than that) and wow, the engine feels more responsive. I'm stock without a tune, have a pedalmax and GT exhaust.
I used the included vacuum line hookups and kept everything as stock as possible. I also kept the intake fins. I dremeled about 2mm inward on all of top side fins and that was enough for the throttle plate to clear (while using the adapter). I didn't touch the bottom side fins at all. The throttle plate opens from the top and never gets close to the bottom ones, even at WOT.
Now, I am a bit concerned with how the TB gaskets and adapter plate all seat. I may have just torqued things differently, I was trying to be careful, I cant hammer down on the TB bolts that go into the adapter, that will strip the threads on this 3D material. I tried to go around in circle and get everything even, but maybe that didn't happen. Can those who used the adapter plate check on if mine seated like theirs?
I hear a wisp noise, but it sounds like its from the intake manifold. I sprayed starting fluid around the gasket area's and the idle didn't jump any. So I don't think I have any vacuum leaks. I'm just curious if this is normal. If so, then at least we have a pic of it so future installers know what to expect.
So what size tube is that and where did you buy it from ? I've got to do this now because I've yet to choose a tube and couplers LOL. Im just confused are two 3.5 couplers a good fit for the stock air box and the gt throttle body ?
